brake issue? they wont work
Old 04-07-2011, 05:37 PM
Blk003GT
Blk003GT's Avatar
Default brake issue? they wont work
so i accidentally let the master cylinder go dry when i was changing my brake fluid and putting on cobra brakes and i can't get them to work. i bled the master cylinder and then started at the back brakes and bled all the old fluid out until there was clean fluid(no air) then the fronts (also no air) and i did this twice and i still have no brakes. the pedal goes down to the floor and then barley works i have to press really hard.
what am i doing wrong?
Blk003GT is offline
Old 04-07-2011, 05:59 PM
zero2005
zero2005's Avatar
bench bleed master cylinder?
zero2005 is offline
Old 04-07-2011, 06:06 PM
Moonshine
Moonshine's Avatar
Repeat entire process?
If you bled everything correctly there should be no reason for the brakes not to work.
_____
You said you did it twice. Did you bleed the master cylinder twice?
Moonshine is offline
Old 04-07-2011, 06:53 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Master cylinder priming...
cliffyk is offline
Old 04-08-2011, 02:40 PM
Brute03
Brute03's Avatar
bleed the M/C again, I had to repeat the process 3 times before i got all the air out
Brute03 is offline
Old 04-08-2011, 02:43 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
abs service bleed
WhiteFoxGT is offline
Old 04-08-2011, 03:38 PM
PurpleIcedGT
PurpleIcedGT's Avatar
5,000 dollars cash that ******** put the front brakes on backwards. Whos gonna take the bet? E-handshake?
PurpleIcedGT is offline
Old 04-08-2011, 03:54 PM
Blk003GT
Blk003GT's Avatar
UM yes I did. Thanks rob ur sooo helpful! LOL
Blk003GT is offline
Old 04-08-2011, 05:39 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
haha. lemme guess, the bleeders were at the bottom.. I wasnt even going to go there, because I thought he knew better hahaha
Old 04-08-2011, 07:14 PM
Blk003GT
Blk003GT's Avatar
like seriously ive pulled motors, trannies, s/c turbo installs, fuel pumps, clutches. i do know wat im doing but this one did get me
Blk003GT is offline
djbigskrilla
09-20-2022 01:04 AM
spectreman
03-31-2016 09:26 PM
Fast-Hands
08-19-2015 06:54 AM
cvarner131
08-17-2015 07:38 AM
FD725
08-11-2015 03:43 AM
Quick Reply: brake issue? they wont work
