Mustang sputtered, died, and won't start now.
Old 06-09-2011, 04:42 PM
fidelcastrol
fidelcastrol's Avatar
Is the sparkplug black and covered in gas on the combustion chamber side or the side that attaches to the coil?
fidelcastrol is offline
Old 06-09-2011, 06:10 PM
PurpleIcedGT
PurpleIcedGT's Avatar
Where in Connecticut are you located?
PurpleIcedGT is offline
Old 06-09-2011, 06:43 PM
Slick72
Slick72's Avatar
The side of the spark plug that is covered is the side in the combustion chamber.
Purple: I live in Meriden.
Slick72 is offline
Old 06-09-2011, 08:22 PM
fidelcastrol
Are any of the other plugs gapped wrong
Old 06-09-2011, 08:31 PM
Slick72
Slick72's Avatar
Nope, the other plugs appeared to gapped correctly. I ordered 8 new OEM motocraft plugs and should arrive tomorrow. EDIT: After closer examination, I turns out one of the other plugs gaps decreased as well. While not smashed in like the other ones that shot out, it was probably on its way there.
http://imageshack.us/photo/my-images...610032919.jpg/
On a far side note, I seafoamed the car 100 miles ago. 1/3 in PCV and another third in gas tank. Maybe the carbon break-ups didn't completely exit the engine?
Slick72 is offline
Old 06-10-2011, 06:30 PM
Slick72
Slick72's Avatar
Well, I got my plugs in. Torqued each plug to about 13lbs. Wen't to start it up and the car would not turn over. All I hear is a click click click from the fuel pump. Seeings how the car would start before the plugs and I let it sit over night with the keys out of car, I don't really see how battery could of drained. I'm hoping its something simple like battery cables. I'm going to try jumping it and see what happens.
EDIT: Got the car started with jumpers. Had to WOT to start it. Once it got running it needed constant WOT to stay going. There was no engine ticking/knocking like previously, but the car popped twice and sounded like it was coming from the spark plugs. The car reeked of gas like before and gas was dripping out of exhaust (turn downs). I'm all out of ideas, i'm going to have a compression test ran to find out if its piston/valve damage. I'll pray its not. Any other ideas?
Heres a video of the car running. Sorry about sound quality, damn long tube headers are so loud.
http://www.youtube.com/watch?v=iL2oXOROLoI
Slick72 is offline
Old 06-10-2011, 08:27 PM
Hangwire
Hangwire's Avatar
Dude your threading is screwed. Just re-tapping the spark plug threading WILL NOT fix the issue. You have to replace the cylinder heads, time-sert it or helicoil it. No other way around it. Its not an easy or cheap fix for the most part.
Hangwire is offline
Old 06-10-2011, 09:34 PM
Slick72
Slick72's Avatar
I had the hole helicoiled. The threading is not the issue anymore, the plug is in there correctly. I've had spark plugs come out before while the threads were still intact and even without the plug in it on previous occasions, the car would start w/o WOT, not smell like gas/leak it out tailpipes, not die without giving it gas and not backfire.
Slick72 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
MEISTERSNFB
03-31-2020 07:50 AM
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang sputtered, died, and won't start now.
