Rear Brake Upgrade
Old 06-23-2011, 05:18 PM
ct_white_stang
ct_white_stang's Avatar
Default Rear Brake Upgrade
Need some help here guys. Do all rear brake upgrades require you to pull the diff cover and axles? I know the Cobra upgrade does and so does the Baer kit I was looking at. Really didnt want to get involved in all that. Thanks
ct_white_stang is offline
Old 06-23-2011, 05:23 PM
ct_white_stang
Nevermind...Drum to disc. Now it makes sense.
Old 06-23-2011, 09:12 PM
04BlueGT
04BlueGT's Avatar
Are you saying you're converting from drum to disk?
I have Cobra f and r, and the axles had to come out. However, I told the wife that since the axles are out, it makes sense to do the gears now. And adding an aluminum cover would make sense, since the old one is off. And a tuner, to recal the speedo is absolutely necessary now....
But if you just want to make the back have a larger disk for appearances, Steeda has a kit to do that without pulling the axles. It comes with a relocation bracket and new disks, but reuses the stock caliper. Again, it's an appearance mod for the most part.
04BlueGT is offline
Old 06-24-2011, 05:03 AM
Fink
Fink's Avatar
when I put cobra brakes on the 7.5, I just pulled the whole rear end out so I didnt have to drop the oil.
Pulling the axles is cake... even easier if you dont have ABS.
Fink is offline
Old 06-24-2011, 08:30 PM
ct_white_stang
I guess what I dont understang is why they have to come out? Sorry, never had to do this on a mustang, I pulled rotors, calipers, etc. from other cars but not involving the axles.
Old 06-24-2011, 09:29 PM
GTtony
GTtony's Avatar
you gonna attempt to do the upgrade your self or have it done by a pro?
I did cobra fronts my self, but am considering having ford installing the rears.
GTtony is offline
Old 06-25-2011, 08:07 AM
brys00gt
brys00gt's Avatar
I could be wrong but from what I've read the rear cobra brakes use the same caliper just a different bracket. Swap the bracket put the cobra rotors on and reuse your caliper. Some guys have also just ground the rear bracket down to make the bigger rotors.fit. there was a write up on it on here I believe.
brys00gt is offline
Old 06-25-2011, 07:05 PM
ct_white_stang
I still dont get why the axles have to come out?
Old 06-25-2011, 09:14 PM
Bpohlman13
Bpohlman13's Avatar
Because the brackets that need to be replaced for the bigger sized rotors are behind the faceplate and the bracket just has a hole in it for the axle to go through.
Bpohlman13 is offline
Old 11-15-2012, 11:15 PM
rafacalz
rafacalz's Avatar
sorry to bring up an old thread, but the links that were used for the steeda adapter are no longer in use, so could some one possibly post a new one with just the bracket adapter. the only thing i'm finding on their site is with a rotor combo.
I'm simply upgrading the rear brakes to the cobra version.
Thanks
rafacalz is offline
Quick Reply: Rear Brake Upgrade
