Headed to the dyno for the first time ever
Old 07-23-2011, 06:13 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
The tune for the GT will kick in the rev limiter much lower than the 4V should. The 4V is a much happier motor reving higher. The A/F of 11.9 is rich for a NA motor. My NA A/F is around 12.9. A supercharged motor should have a lower A/F ratio than a NA motor.
I'd guess a proper tune and rev limit would get you to around 285-290rwhp. Only way to know is to do it though. I'm sure you will see a noticeable gain once that is corrected.
I don't see gears listed in your sig. If you are stock gears now, swapping to 4.10 will make a huge difference with the 4V (let it rev).
GOOD LUCK and let us know how this turns out for you!!!
TRUEBLUE3934 is offline
Old 07-23-2011, 08:25 PM
jeh4269
jeh4269's Avatar
I'm gonna pick up an SCT tuner on Monday and get it tuned as soon as I can.TRUEBLUE I have 4.10's here,just need to get them installed.I think the low rev limiter prob hurt me the most.After I get her tuned I'll post the new numbers.Really hoping for over 290.No matter what HP I end up with it's def alot more fun to drive than the 2v was.
jeh4269 is offline
Old 07-24-2011, 01:55 PM
lizzyfan
Underboss
lizzyfan's Avatar
Who did your dyno run
lizzyfan is offline
Old 07-24-2011, 03:14 PM
ctgreddy
ctgreddy's Avatar
yeah that's cutting down way too early man. I'd say between a 12.8-13.0 is ideal for an n/a afr. i wonder why it's hitting the rev limiter so early tho? a stock gt's limiter doesn't kick on until around 6000 doesn't it?
ctgreddy is offline
Old 07-24-2011, 04:22 PM
uberstang1
Chupacabra
uberstang1's Avatar
I think there is some kind of conflict woth the gt ecu and the cobra crankshaft and or camshaft position sensor
uberstang1 is offline
Old 07-24-2011, 04:38 PM
ctgreddy
ctgreddy's Avatar
would it be possible to find a cobra ecu on ebay or corral and just throw it in, or are there harness differences? that seems like the easiest way to go about it.
ctgreddy is offline
Old 07-24-2011, 10:09 PM
jeh4269
jeh4269's Avatar
I had Godspeed Performance dyno it.It was easier to use the GT ECU and get it tuned than to swap in a Cobra ECU.My tach read 5400 and his computer said 5150 when the limiter kicked in.He got his reading straight off the carnkshaft.Hoping to get another 30rwhp after everything is fixed during the tune.He said the dyno is a Landon C.Anyone ever heard of them?
jeh4269 is offline
Old 07-25-2011, 05:27 AM
uberstang1
Chupacabra
uberstang1's Avatar
John I have a cobra ECU, its not difficult to install you simply removed the passenger interior kick panel, loosen the bracket and then its plug and play.
Old 07-25-2011, 06:03 AM
ctgreddy
ctgreddy's Avatar
you can expect your stock tach to be off a little bit. i know in my '95 i had an autometer tach with a shift light set to 6400, and when the shift light came on my stock tach was up around 7k.
ctgreddy is offline
Old 07-25-2011, 08:03 AM
jeh4269
jeh4269's Avatar
Hey Keith I was told that the main issue with swapping in a cobra ecu is with pats.I guess my keys wouldn't start the car.IDK.I was told it was easier to let the gt ecu in and tune it.I'll ask Dave and see what he sats.Your ecu is a 97 correct?Would that work with a 96 engine?I think it will.I thought the 96-97 cobra's were pretty much the same but in 98 they were a little diff,or are the ecu's the same all three yrs.
jeh4269 is offline
Quick Reply: Headed to the dyno for the first time ever
