fitment of 17x9 and 17x10.5
Old 07-31-2011, 10:41 AM
Bmitchell373
Bmitchell373's Avatar
Default fitment of 17x9 and 17x10.5
I'm finally ready to order wheels and tires. This is the best deal I've found. http://www.latemodelrestoration.com/...Wheel-Tire-Kit
I plan to do a cobra brake upgrade soon as well, I should have no problem with the 17s. I just want to make sure I wouldn't have any tire rub. Nittos specs are a 11" wide front and a 12.5" rear. Thanks for any input.
This is the brake kit i found.
http://www.steeda.com/store/steeda-c...d-mustang.html
Has anyone used the power slot rotors?
Bmitchell373 is offline
Old 07-31-2011, 11:11 AM
Moonshine
Moonshine's Avatar
Cool man! You'll have no problems.
Moonshine is offline
Old 07-31-2011, 11:48 AM
KillJoy
KillJoy's Avatar
I have 17x9 17x10.5 with nittos. I do rub a little bit at a full lock u turn, but thats honestly because the car is so low, not because of the wheel fitment. You'll love the 315s out back.
KillJoy is offline
Old 07-31-2011, 12:10 PM
945LSTANG
945LSTANG's Avatar
Have you thought about a DR out back? I don't much care for those wheel/tire packs even though this one is better than others. They just really aren't a "deal". I did 4 wheels and tires of my choice for the same price and I used better tires than 555s IMO.
945LSTANG is offline
Old 07-31-2011, 01:20 PM
lizzyfan
Underboss
lizzyfan's Avatar
Yea I had 10.5 Bullitts with both Nitto's and Sumi's with zero issues
lizzyfan is offline
Old 07-31-2011, 04:33 PM
Bmitchell373
With it being my dd I don't want a DR, I can get discounts threw my work on some tires, I have to see what all they have. I'm not set on nittos, but i have never heard bad about the 555 other than there not a DR.
Old 07-31-2011, 07:02 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
You can have BETTER braking than the Cobra kit you plan, by just upgrading your pads, fluid and SS lines. Your looking at about $350 and is far cheaper than the Cobra upgrade with BETTER stopping power.
Save some coin and peep Brakes Upgrade thread (sig)
Jazzer
Jazzer The Cat is offline
Old 07-31-2011, 10:33 PM
teej281
4.6L Section Moderator
teej281's Avatar
Or you can visit my sticky and get 03 cobra brakes on all four corners with stainless lines for right around 600-650 if all the pricing has remained unchanged.
teej281 is offline
Old 07-31-2011, 11:20 PM
Moonshine
Moonshine's Avatar
But jazzer...cobra brakes with all of those upgrades. YES PLEASE. My car stops faster than a....umm...well faster than a stock cobra. Lol.
Old 08-01-2011, 05:34 AM
Jazzer The Cat
Retired Moderator
If the brakes are capable of locking-up the wheels (or trigger the ABS) the ONLY issues left are those created by heat.
You do premium fluid, pads and SS lines with Cobra brakes, you won't necessarily stop better, but will have a bit better cooling and a small mechanical advantage. I had originally installed a set of '03 Cobra brakes out back and was unable to feel any real difference. Due to this mechanical advantage, they MUST have been better, but nothing of which I could quantify by "seat of the pants feel".
Remember, the brakes are ONLY as good as the tires and are not distinguishable from OEM once they lock up or trigger the ABS. As mentioned, the mechanical advantage of a larger rotor is helpful for pedal feel and some cooling. But, on the street, there should never be a need for such cooling, as you would have to be using poor braking techniques to get there. If one was to be running the open-track all the time, a full-set of Cobra brakes would only get you a short bit further and then would need to either add cooling or upgrade to race brakes to address the issues of heat.
With all this said, install the upgrades in my guide on BOTH sets of brakes on two different cars identical in every other way..... I am willing to bet you both stop within at nearly the same location if not the same. If the extra $$$ is worth it for this and/or the visual upgrade, go for it
Jazzer
Quick Reply: fitment of 17x9 and 17x10.5
