throttle body stuck/not responding HELLPPPP!!!
Old 08-12-2011, 09:27 AM
Maik0819
Maik0819's Avatar
Exclamation throttle body stuck/not responding HELLPPPP!!!
so my battery was giving me troble so i went to advace auto part to gett it recharged since i dont have the money to buy a new one. so i took it off recharged it and than put it back in.(keep in mind the only problem with the car before all this was that the battery was bad and i had to puch start the car) and once it was in i went and the car turned on much nicer but i see the check engine light and the little rechent light, i gave it gas to see the reves wernt going anywhere. i need help guys. its a 2006 mustang gt.. and on top of that my fuel gague is stuck on full...... FML
Maik0819 is offline
Old 08-12-2011, 09:59 AM
TOMMY01GT
TOMMY01GT's Avatar
Sounds like a computer issue or something.
Is there a special methond on S197 mustangs for removing and replacing the battery terminals to prevent computer damage?
TOMMY01GT is offline
Old 08-12-2011, 11:46 AM
Maik0819
Maik0819's Avatar
i just found out it is a computer issue and appretrantly the computer is not recgonizing the throttle body..
Maik0819 is offline
Old 08-12-2011, 12:03 PM
amoosenamedhank
amoosenamedhank's Avatar
I was slightly confused until I read the S197 part... drive by wire... gotcha.
amoosenamedhank is offline
Old 08-12-2011, 12:06 PM
Maik0819
Maik0819's Avatar
amoosenamedhank what????
Maik0819 is offline
Old 08-12-2011, 12:09 PM
TOMMY01GT
TOMMY01GT's Avatar
Drive by wire...there is no physical connection between the TB and the accelerator.
Might try to unhook the battery again, and let it sit a minute or 2?
Old 08-12-2011, 12:40 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
or hook a scan tool up and retrieve the codes, then we can go from there. Sounds like you have more than just a dead battery issue. Also, dont forget to re-initialize your windows
WhiteFoxGT is offline
Old 08-12-2011, 06:46 PM
Maik0819
Maik0819's Avatar
Thank you guys
Maik0819 is offline
Old 08-12-2011, 08:04 PM
FlamingoGT
FlamingoGT's Avatar
you might try asking in the S197 section also:
https://mustangforums.com/forum/4-6l...iscussions-69/
you will find more people there with your car than here...
FlamingoGT is offline
Old 08-13-2011, 01:06 PM
945LSTANG
945LSTANG's Avatar
He was confused at the OP and title because our sn95s have a cable operated TB whereas yours is controlled by the CPU. You technically posted in the wrong section but it's not that big of a deal. I'm sure you would get similar responses from the s197 section.
945LSTANG is offline
Quick Reply: throttle body stuck/not responding HELLPPPP!!!
