How much hp and 1/4 mile time?
i have a 2004 mustang gt.
geared to 3.73, 245/45/17
K&N Cai, bigger throttle body, c&l intake plenum, bassani cat back, shortshifter, oil blowback system, and a diablo sport tuner.
I can get a 14.4 in it but thats the best i can pull. and my launch is between 1200 and 1500. what should be the next thing to put on this? im trying to still keep a good mileage because it is a dd.
Need new wider wheels and better tires and a new set of lower control arms. You have plenty of bolt-on's. Thats enough money wasted. New wider wheels with wider tires will help with traction so you can launch a little harder. Control arms will help that too. I was going to suggest a midpipe but youre in nazifornia and that wouldnt fly unless you got the Magnaflow which I think is CARB stamped. Not 100% sure on that but its worth a shot.
Biggest help here is going to be a better wheel/tire package and lower control arms to hook up better. Also, driver mod is probably needed. That time is similar to mine and I have a good 2-300 pounds on you, taller gears than you, and you probably make about the same or more power than I do. I ran a 14.5 @ 95mph. You should easily be in the 13's as you sit if you drive well. So practice might help you too.
That being said, I would bet some decent tires would give you the best improvement in ET at the track. A pair of DRs could get you as much as 0.6 seconds off your ET. That and practice are my first suggestion for you.
teej281 typing reply same time as me...
Also, if you haven't already... take anything out of your car that is not neccessary (jack, spare tire, etc). Removing the front swaybar when you go to the track will help your weight transfer on launches (plus drop another 20lbs off the front of the car).
^ Good advice above given already.
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
