Blower cams SHM 2
Old 10-21-2011, 08:11 PM
  #21
97stanger
97stanger's Avatar
stock valves fred?
97stanger is offline
Old 10-21-2011, 08:27 PM
  #22
zero2005
zero2005's Avatar
IIRC all MHS cams are good w/ stock valves & springs up to stage 2. i'm running stage 2 turbo cams with the "stock mod" valves (well, 7 out of the 8 are, 1 is a completely stock valve) which are just stock valves ground down a tad, and there was 0 issues.
i think stage 2.5's & 3's are where you need either notches or modified valves or both...
zero2005 is offline
Old 10-21-2011, 08:34 PM
  #23
97stanger
97stanger's Avatar
^got ya, well theres some good info for ya rockwell if you decide to go MHS. I'm sure Nick wouldnt mind explaining everything as well. Whatever you do and read on here, DO NOT buy CMS stage 3s without notched pistons lol. I read all over the internet that you dont need notched pistons or valves, so I didnt do either. When trying to degree them I couldnt even turn the motor over because of PTV contact. I stepped down to the 2's and wala.
Old 10-21-2011, 08:54 PM
  #24
lizzyfan
Underboss
lizzyfan's Avatar
Originally Posted by 97stanger
stock valves fred?
Yep, intake valve is ground down for more clearance
lizzyfan is offline
Old 10-22-2011, 12:41 AM
  #25
Rockwell28
Rockwell28's Avatar
Good deal I see some great info being laid out here and i was planning on the mhs 1 to begin with after I get intercooled but someone approached me on another forum when he found out i was looking into blower cams its a long story but its like a 99% chance it will be the mhs stage 1 blower cams that I will be going with in the future. Thank all of you guys for all of the info laid out in here so far.
Rockwell28 is offline
Old 10-22-2011, 09:33 AM
  #26
97stanger
97stanger's Avatar
yeah, I thought modified valves were required for his stage 2's.
Not a problem, lots of guys on these forums are informative and have been in your shoes before. Keep us posted!
Old 10-22-2011, 10:06 AM
  #27
zero2005
zero2005's Avatar
IIRC they are not required, just helps clearance so there's less of a chance to run into PTV clearance problems, and i think they flow slightly better too. as i said, i'm running 7 out of the 8 as nicks "stock-mod" valves, and 1 is a completely stock valve. 1 got bent, so i just swapped a stock in its place, i called him before i did so and he said it was perfectly fine to do so.
zero2005 is offline
Old 10-22-2011, 12:59 PM
  #28
97stanger
97stanger's Avatar
I really should have gotten my pistons notched, the cms 3's sound so bad ***
GimpyHSHS
19
12-19-2023 01:12 PM
uberstang1
12-07-2017 07:10 AM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Blower cams SHM 2
