Boost gauge vac line ?
Old 02-08-2012, 08:35 AM
scooter3
scooter3's Avatar
Default Boost gauge vac line ?
Can I tie right into the vacuum line that goes to my BOV for an accurate vac/boost reading or is there a better place to tie into?
scooter3 is offline
Old 02-08-2012, 08:47 AM
bopiela
bopiela's Avatar
glad you asked. My gauge will be here today! haha.
bopiela is offline
Old 02-08-2012, 08:58 AM
disposablehero27
disposablehero27's Avatar
Also glad you asked. I have mine and no idea where i should run it. I figured somewhere in on or around the intake. Drill and tap kind of thing. But i dont know
disposablehero27 is offline
Old 02-08-2012, 09:06 AM
scooter3
scooter3's Avatar
Well I am going to try it. I can't think of any reason why it would not work. Alot of guys run it off the drivers side fuel vac relay or off the TB. The cav hose going to my BOV is coming right off my lines from the TB.
scooter3 is offline
Old 02-08-2012, 09:26 AM
uberstang1
Chupacabra
uberstang1's Avatar
I got mine spliced into a line right off the manifold, works fine. Definatly no need to drill and tap the intake
uberstang1 is offline
Old 02-08-2012, 09:51 AM
scooter3
scooter3's Avatar
Worked like a charm. Vac shows around 19 at idle and boost climbs when I get on it.
scooter3 is offline
Old 02-08-2012, 10:11 AM
dwtjr3
dwtjr3's Avatar
This is what i did, spliced mine in right around my TB and works fine
dwtjr3 is offline
Old 02-08-2012, 11:28 AM
MustangMan00
MustangMan00's Avatar
mines spliced into the fuel pressure sensor on the drivers side
MustangMan00 is offline
Old 02-10-2012, 02:35 PM
disposablehero27
dwtjr3, where on the TB? Mine is a mechanical gauge... not sure if everyone's is here or not. i just have the clear vac line, with no clue where to put it on my 96 cobra.
Old 02-11-2012, 01:00 AM
MustangMan00
the top right of the pic, do you see the clear line coming out of the firewall?
follow that down to the white T fitting, coming off of the fuel sensor, this is a common spot to hook em up at
or the red wires coming out right after the throttle body
Quick Reply: Boost gauge vac line ?
