Gears rpm question
Gears rpm question
Was thinking of putting in 4.10s on an 01 Gt auto. A lot of guys have been saying they don't notice a big change in rpm or mpg, but when I calculated the gears it said at 65 mph I'm turning 2.5k, and 70 mph turning almost 2.8k. At 2k where I usually am going near 70, it drops down to 53 mph.
So what's everyone's input on the calculations? Is it accurate and did you notice a drop in mpg? I calculate my mpg every time I fill up at the pump and I get a combined 22 mpg on average.
Look at the math i just gave you and look at post #3 in this link http://www.moddedmustangs.com/forums...s-mileage.html
As Rockwell28 said, and it is refreshing to hear someone else say it, lower rear-end gears (higher numerically) will reduce your highway fuel economy. Those that say it will not either do not drive many highway miles or are being less than truthful.
Back in 2007 when I installed 3.73s I had a 55 mile, each way, commute with 40 of those miles being on I-95 between Saint Augustine and Daytona, at 75 to 85 mph. The gears cost me a solid 1.25 mpg, from a 22.75 average to 21.5--driving over the same roads at the same time of day. This was not a surprise to me, nor did I consider it to be a major influence on my budget.
110 miles/day * 5 days = 550 miles/week:
Some 1.41 gallons more per week. Even at today's cost for 93 octane of $3.899/gallon (just filled up my bike 30 minutes ago) that's only a whopping $5.50 per week.
Or, a couple of draft beers at a relatively cheap bar¹...
¹ - I like to convert life's costs into the quantity of beer they represent, it provides a much more meaningful comparison than dollars.
- at 22.75 mpg that's 24.18 gallons;
- at 21.50 mpg it is 25.58 gallons;
There will be a noticeable difference in rpm between your stock 3.27 and 4.10. You are gaining 25.3% torque multiplication and 25.3% rpm increase to go with it. Take any current rpm you run now and multiply it by 1.253 to get the new rpm with 4.10 gears. That means what used to be 2200rpm will now be 2757rpm.
Your highway mpg will absolutely drop. Many variables exist so predicting the exact drop for you is impossible. However, I also saw a drop comparable to what Cliffy stated above.
All of that being said, most guys really like the 4.10s in their auto Mustang. I'm pretty certain you would fall into that category also.
Go for 4.10 and you won't be disappointed.
If you are still uncertain about such a large jump, you can go with 3.90 gears and trim back about 5% of that jump.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
