Poly Trans mount review...
Old 03-02-2012, 04:57 PM
ctgreddy
ctgreddy's Avatar
Default Poly Trans mount review...
My stock Trans mount was ripped and worn, figured I'd try out the poly mount they sell on summit. Install was simple and good, looks very solid. However this is not the mount for me, or anyone that uses their car As a dd. the car vibrates a good deal more now at all speeds and it also transfers even more noise into the cab then before. I'll be ordering an oem style mount soon, so if anyones Interested in this ill sell it pretty cheap. Would be good for a weekend/track car just not for me.
ctgreddy is offline
Old 03-02-2012, 05:09 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Yup, polyurethane bushings and mounts do that. But it's one of those things no one believes until they have "been there and done that". They also self-destruct, getting brittle and then crumbling, after 35k to 50k miles/2-5 years of DD use...
Been there and done that...
cliffyk is offline
Old 03-02-2012, 05:11 PM
01GTDropTop
01GTDropTop's Avatar
Yeah, I made that discovery as well. I went with prothane engine and trans mounts. The engine mounts were awesome, but that trans mount was yanked a month later. Way too harsh for a DD.
01GTDropTop is offline
Old 03-03-2012, 11:02 AM
ctgreddy
ctgreddy's Avatar
yeah this wont even be lasting till the end of the week. lol
ctgreddy is offline
Old 03-03-2012, 06:06 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
I had poly engine and trans mounts. I could definitely tell a difference but I didn't think it was that bad.
Have you priced OEM mounts yet? Mine are getting to that age they need replaced.
WannaBeGearHead is offline
Old 03-03-2012, 08:36 PM
01GTDropTop
OEM trans mount is about $65.
Old 03-04-2012, 03:00 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
Yeah you always have to have some rubber in there or the car will rattle to pieces, not to mention the extra stress on the trans case. I'm not sure how ours are mounted but depending on the car, stiff mounts can break mounting tabs with a hard shift.
The engine mounts for my other car, I actually took the factory mounts, put them in a press, compressed them down and welded a bar across to hold them down. so the mounts are still rubber, but stiffer and don't move as much. I'm very happy with how they turned out.
69MustangCoupe393cid is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Poly Trans mount review...
