Tire puncture -_-
Old 03-16-2012, 06:27 PM
supersnake67
supersnake67's Avatar
The inside of the tire where the patch is , is about the size of a half dollar so you need about half that distance from the puncture. Judging from your pic I would've had no problem patching that. And the tire integrity will only be an issue if you have someone "PLUG" the tire cause they suck or someone tries to patch the sidewall..... Trust me I've seen it all. And if someone tells you that mounting and dis-mounting your tire will ruin the bead cause you have 35's are idiots !!!! Unless you have rubber band tires or run flats you wont have those problems.
supersnake67 is offline
Old 03-16-2012, 06:29 PM
humansieve
humansieve's Avatar
Don't plug it, patch it. But if I were racing I would buy another. No sense in crashing to save a few hundred.
humansieve is offline
Old 03-16-2012, 06:33 PM
crash
BrandofPoop
crash's Avatar
I didn't know that plug and patch were different terms. Hmmm well I'll have a backup tire then. I'm fine with that honestly. Where's Jazzer when I need him lol
crash is offline
Old 03-16-2012, 06:35 PM
crash
BrandofPoop
crash's Avatar
I guess the guys I spoke to are dumb then and won't be seeing my services then lol.
crash is offline
Old 03-16-2012, 06:41 PM
jeh4269
jeh4269's Avatar
I think you're doing the right thing getting a new tire.I believe it could've been fixed but now you'll have a spare and piece of mind at the track.
jeh4269 is offline
Old 03-16-2012, 07:03 PM
Repzard
Repzard's Avatar
Could have been fixed for sure with a patch.
But I can agree with not using it at the track.
Safety is #1 I agree CRASH.... , but for sure can be use as a spare.
Where that hole is should be okay to patch legally its not on the side wall and looks to be a good inch away.
GL
Repzard is offline
Old 03-16-2012, 07:17 PM
crash
BrandofPoop
crash's Avatar
Thanks for the advice guys. I'll look into a patch when my new tire comes in.
crash is offline
Old 03-16-2012, 08:21 PM
sv650lex
sv650lex's Avatar
On my old winter beater it took 3 plugs with glue in a cut on the sidewall. Tire out lasted the car. Almost 2 years.
sv650lex is offline
Old 03-16-2012, 11:46 PM
99 GT vert
99 GT vert's Avatar
that is very border line if it is with in a half inch of the tread it can not be repaired but if it is more than a half inch away take it to a shop that will patch and plug it for you i know for sure discount tire/ americas tire will do both a patch and a plug and it should be free as well
99 GT vert is offline
Old 03-16-2012, 11:55 PM
2000VertGT
2000VertGT's Avatar
I guess you can't go wrong with buying a brand new tire. As for using that one as a back-up, whichever shop you take it to, make sure the patch plug they use looks like this I know sears uses them because I worked in the auto center for 3 years. That type is the best way to fix a hole in a tire.
2000VertGT is offline
Quick Reply: Tire puncture -_-
