How many of you guys are running 18x10s with the H&R ss's?
Old 04-18-2012, 08:22 PM
  #21
dwtjr3
dwtjr3's Avatar
Originally Posted by teej281
I'm running 335's on 18x11's and I just had to run a spacer(to keep from hitting the subframe bolt...thats for Crash), and I had to roll my fenders. The tires that came on the wheels I have now were 315/30-18 BFG DR's and my friend with H&R SS springs cut the sidewalls up real bad on them because he didnt roll the fenders.
I definitely recommend rolling the fenders and maybe some small spacers. The R888's run pretty wide from what I've seen on a couple cars. Just some food for thought. The D-specs should do well controlling the drop and the motion of the suspension. Just make sure to not loosen it all the way all the time to prevent excessive suspension articulation that doesn't need to be there.
Yeah the r888s are definitely wider then the nitto 305's
dwtjr3 is offline
Old 04-20-2012, 12:16 PM
  #22
Gt04
Gt04's Avatar
Haven't forgotten bout those pics, its been raining here since I said I'd take them and I can't even get my car down my dirt road to drive it right now because of it lol
Gt04 is offline
Old 04-20-2012, 08:14 PM
  #23
dwtjr3
dwtjr3's Avatar
Its cool man. Could you please try and get some pictures of the inner fenders some how? As well as a few of the whole rear of the car
dwtjr3 is offline
Old 04-21-2012, 01:01 PM
  #24
LilRoush
LilRoush's Avatar
Another thing that I haven't seen mentioned yet is the offset of the rear wheel. That will come into play BIG TIME when looking at a tight squeeze in the back. When I swapped the 18x10 off my '00 onto my '98, what was a fine fit without issues had a rubbing issue on the inner edge. Just that little change in rear axle length between the two generations was enough for the wheel to fit fine vs rub. Had to massage the inner liner a bit. It's just as harsh as the outside edge. Any cuts into the tires and they aren't safe to drive on anymore. Side wall isn't a blow out you want to risk going down the road.
A different offset between wheel styles will have the same impact on where the wheel sits in relation to the inner/outter fender edge.
LilRoush is offline
Old 04-23-2012, 12:12 AM
  #25
kingrukus
kingrukus's Avatar
running 285 on my rear 18x10s and h&r ss springs. no rubbing
kingrukus is offline
Old 04-23-2012, 09:27 PM
  #26
teej281
4.6L Section Moderator
teej281's Avatar
Originally Posted by 97stanger
for those of you guys that rolled your fenders, did you use the eastwood fender roller? Do you have any tips/secrets and do you remember which holes you had the nuts in? I spent a lot of time with mine this past weekend and couldnt exactly get it adjusted right
We used the Eastwood tool, but I dont remember the specifics on how we put it on the car.
teej281 is offline
Old 04-23-2012, 09:33 PM
  #27
dwtjr3
dwtjr3's Avatar
Ok thanks man ill keep that in mind, what did you do to take care of the fender lining issue?
dwtjr3 is offline
djbigskrilla
09-20-2022 01:04 AM
bryan616fl
01-25-2019 09:07 PM
ShaneB26154
08-28-2015 04:47 PM
MXBT187
08-20-2015 02:36 AM
Stilz
08-19-2015 06:17 AM
Quick Reply: How many of you guys are running 18x10s with the H&R ss's?
