Tuner or cams?
#21
So not an entire engine but the Top end of the engine heads,cam,intake.
#23
But as for cams vs tuner. When you install cams you dont really need a dyno tune but it helps the car perform a lot better with one, and in order to get a dyno tune you need a handheld tuner or a chip so i would say tuner first.
I agree with these other guys i would say save up for a PI swap. You will really notice a difference in performance when you do the swap
#24
I turn 17 next month and I'm doing the PI swap right now, should be finishing it up this weekend.. It did take a little bit for everything, I'll let you know what the results I get out of it. I did just order a tuner also, so I'm hoping to see a pretty significant difference after all of this.
#27
Well, some could probably see this coming, but I say ditch the SOHC 2v and get a DOHC 4v motor. Just my two cents. Costs a little more, but the initial power and gains with each mod are so much greater.
If you're willing to look a 4v swap can be done for just a couple hundred more than a PI swap.
I'll probably be alone in recomending this, but I'm happy I made the jump to a 4v and stayed away from the 2v.
Nice looking car, OP. Love the color...welcome and happy modding!
EDIT: To answer your question, you can do the PI swap with the motor in, but to a full swap the heads have to be removed wich means the front cover comes off, and space will be really tight.
#29
Thank you, The thing I'm worried about is the price of labor. Someone told me i'd be looking at an easy 20 hour job? that doesn't sound right imo. If anyone has any info on the price they paid for the swap, that would be more than helpful.
@ slow 'stang: How much did you pay to jump to a 4v ? and did you do it yourself, or pay a person/shop?
#30
