Power on a stock crank?
Old 11-21-2012, 01:15 PM
Stevo86
Stevo86's Avatar
Default Power on a stock crank?
Hey guys I'm looking for opinions on an engine build. Everything is all ready to go but I'm torn on whether or not I need the forged crank over the stock. I'm looking to build a nitrous motor. Probably going to run a 200-250 shot on it. How much reliable power has everyone seen on a stock steel crank?
Stevo86 is offline
Old 11-21-2012, 01:47 PM
Forced Air
Forced Air's Avatar
I wouldn't risk it with the stock crank. It would be well worth the money to buy something that WILL hold the power rather than MIGHT hold the power.
Forced Air is offline
Old 11-21-2012, 04:20 PM
dwtjr3
dwtjr3's Avatar
^this
Because 250is a big shot
dwtjr3 is offline
Old 11-21-2012, 04:43 PM
uberstang1
Chupacabra
uberstang1's Avatar
stock cranks are good for 600, ull be fine
uberstang1 is offline
Old 11-22-2012, 09:47 AM
jtb727
jtb727's Avatar
^^^ agreed
jtb727 is offline
Old 11-22-2012, 10:06 AM
Mustang_NTriangle
Mustang_NTriangle's Avatar
Stock crank is not your problem, I am assuming you are already forged upper? I would spend money on built tranny and rearend with that kinda of torque.
Mustang_NTriangle is offline
Old 11-22-2012, 12:16 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
as long as you use good rods and pistons, and they arent too heavy, stock crank will be fine, having to add heavy metal to them makes them weaker but lighter components wont be an issue
im aiming for 500rwhp with my stock crank FWIW
sn95_331_GT_ yellow is offline
Old 11-22-2012, 05:23 PM
Stevo86
Stevo86's Avatar
Manley forged H beams and forged Diamond pistons with the rings set lower specifically for the giggle juice. Ported stock heads with upgraded springs and nitrous cams. The clutch was just replaced with a stock cheapo so I am well aware that will be exploding into pieces shortly. Thanks for the input fellas
Stevo86 is offline
Old 11-23-2012, 05:57 PM
mineralpony
mineralpony's Avatar
You should be fine.
mineralpony is offline
Old 11-23-2012, 06:34 PM
01GT4.6
01GT4.6's Avatar
Out of curiosity, how much experience do you have with nitrous, why kit will you be running and what fuel system?
01GT4.6 is offline
Quick Reply: Power on a stock crank?
