Questions for you guys with forged motors
Old 08-16-2013, 09:50 AM
dwtjr3
dwtjr3's Avatar
Default Questions for you guys with forged motors
I have a forged rotating assembly as well as arp rod bolts, dss racing main support, and arp main support bolts.
My question is what other bolts and stuff will I need so that I can put the motor together?
I am looking for what other things I will need to buy to get the motor together and running
dwtjr3 is offline
Old 08-16-2013, 10:27 AM
Kerns
Kerns's Avatar
Arp side bolts, arp crankshaft bolt, arp head studs. Can reuse the timing chain tensioner bolts and oil pan bolts etc. I would replace the timing chain guides as well.
Kerns is offline
Old 08-16-2013, 09:39 PM
dwtjr3
dwtjr3's Avatar
ok cool so that is all the bolts I would need then?
And what oil pump do you run kerns?
dwtjr3 is offline
Old 08-16-2013, 11:39 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Mmr pump or cobra pump. Never saw anything wrong with either
WhiteFoxGT is offline
Old 08-17-2013, 12:25 AM
Soldier GT
Soldier GT's Avatar
Hey dw if you can't find the stuff that you need used, I would suggest you check out Mod Max racing. Pretty cheap, excellent warrenty and best thing, customer service is outstanding. Also I agree with the man with the plan Kerns. I would most def change the timing chain guides as well. Learned that one the hard way...What's your plans for the car? Are you planning non bumping the boost up a little?
Soldier GT is offline
Old 08-17-2013, 01:05 AM
Kerns
Kerns's Avatar
I'm running a melling billet aluminum oil pump. Yes that's all you'll need as far as bolts are concerned. Don't forget main bearings and rod bearings.
Kerns is offline
Old 08-17-2013, 12:24 PM
dwtjr3
dwtjr3's Avatar
I planned on all clevite bearings.
And did you guys use oem gaskets?
dwtjr3 is offline
Old 08-17-2013, 01:34 PM
Kerns
Kerns's Avatar
Yes to OEM gaskets. So far they seem to be holding up just fine
Kerns is offline
Old 08-17-2013, 05:04 PM
dwtjr3
dwtjr3's Avatar
Ok sounds good.
And clevite bearings ok as well? I've heard a lot of good things about em
dwtjr3 is offline
Old 08-17-2013, 05:10 PM
Kerns
Kerns's Avatar
Yeah, i'm running Clevite H series.
Kerns is offline
Quick Reply: Questions for you guys with forged motors
