Anyone install a vacuum block before?
Old 10-31-2013, 10:23 PM
dwtjr3
dwtjr3's Avatar
Default Anyone install a vacuum block before?
I am confused on what lines feed the vacuum blocks?
Like in the treadstone one they have ****** fittings on the left and the right, which lines go there?
http://www.treadstoneperformance.com...t+Vacuum+Block
And will I be able to get rid of all my factory vacuum lines and run them off of the vacuum block to get rid of the T's?
dwtjr3 is offline
Old 11-01-2013, 07:41 AM
uberstang1
Chupacabra
uberstang1's Avatar
You run whatever line you want to the end of the block, it goes with a 3/8 plug to block the other end in the description. Yes u can run all your lines to it but its good to have certain things just run directly off the intake such as the fuel pressure reg.
uberstang1 is offline
Old 11-01-2013, 03:34 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I usually hook up a dyson or an oreck straight to the battery for extra vacuum.
WhiteFoxGT is offline
Old 11-02-2013, 07:21 AM
dwtjr3
dwtjr3's Avatar
Is that what that's for doug? Haha
So when I go return style ill keep the fuel pressure regulator on the intake.
What vacuum lines are 3/8? The one to the intake manifold?
And is tthere any other vacuum lines i should leave instock location?
dwtjr3 is offline
Old 11-02-2013, 07:24 AM
dwtjr3
dwtjr3's Avatar
Why does my op keep putting ****** in instead of what's I'm trying to say?
dwtjr3 is offline
mtgldr
02-03-2024 09:00 PM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Anyone install a vacuum block before?
