Couple of probaby stupid questions
Old 11-06-2014, 09:02 AM
2004GTconvertable
2004GTconvertable's Avatar
Default Couple of probaby stupid questions
I am new to Mustangs, purchased a 2004 GT Convertible last month. I have a couple of probably stupid questions. What is meant by MODULAR? Why is this series of Mustangs called NEW EDGE? How do you tell difference between BASRE, DELUXE and PREMIUM? Thanks for your time.
Mike
2004GTconvertable is offline
Old 11-06-2014, 10:44 AM
302Travis
302Travis's Avatar
Not sure about any of those myself except cheating and using the vin online and some sites can tell you.
302Travis is offline
Old 11-06-2014, 01:54 PM
Z28KLR
Z28KLR's Avatar
The term "modular" had to do with assembly line setup and tooling, and how it could all be switched over to produce the various engines (4.6 and 5.4 in 2 and 4V configuration) in a short period of time. The common misconception is that "modular" implies interchageablity of components between the various engines.
Base model is a V6 car. Both "base" and "GT" models could be had in Deluxe or Premium trim packages. Premium included things such as leather upholstery, etc.
Z28KLR is offline
Old 11-06-2014, 02:06 PM
302Travis
302Travis's Avatar
I have owned two deluxe gts with leather.. one i had the window sticker for and it said deluxe. I have no idea how to find out without vin
Old 11-06-2014, 02:29 PM
2004GTconvertable
What in the vin tells trim level?
Old 11-06-2014, 07:27 PM
Kornnut
Kornnut's Avatar
I don't think there is anything that would.
Kornnut is offline
Old 11-07-2014, 07:21 AM
dhavi4226
dhavi4226's Avatar
Trim codes along with other specifics are located on the certification label. This label is on the driver door jamb "B"Pillar.
dhavi4226 is offline
Old 11-07-2014, 07:34 AM
99GTvert
is my username.
99GTvert's Avatar
New edge was the name used internally by Ford.
99GTvert is offline
Old 11-07-2014, 10:26 AM
302Travis
302Travis's Avatar
Im assuming it woukd be in the vin? Because if not i dont think ford would have a way to tell you which it is.
I will have to look at my door jam on my new one! Never thought of that
Old 11-07-2014, 12:08 PM
VTX1800N1
VTX1800N1's Avatar
Go to www.etis.ford.com and click on "Vehicle". Enter your VIN and when you get the return expand the information on the right. It will tell you every option that was on your car when it left the factory and will also let you know of any service campaigns or recalls.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Quick Reply: Couple of probaby stupid questions
