Heads Up Display
Old 02-12-2017, 01:54 PM
Turn Two
Turn Two's Avatar
Default Heads Up Display
Anyone installed a Heads Up Display on a 96 Mustang GT? I am tired ...of replacing the speedometer gear on my wife's hotrod. I purchased a generic HUD off Ebay and it does not work... maybe because this was the first year of OBD??? Thanks for any assist...
Turn Two is offline
Old 02-13-2017, 06:09 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I downloaded a HUD app to my phone a couple years back that blue toothed into the obdII port and it actually worked pretty well. Can't remember the name of it but it might be worth researching.
fastbackford351 is offline
Old 02-13-2017, 09:10 AM
Turn Two
Turn Two's Avatar
The HUD I purchased shows gas mileage and engine temp. No speed or RPM. I'm thinking the OBD for '96 did not provide that info?
Turn Two is offline
Old 02-14-2017, 05:24 PM
Z28KLR
Z28KLR's Avatar
I would consult with either the manufacturer or the seller of your device. Most likely a compatibility issue of some sort? As far as OBD2 parameters your vehicle should have rpm and vehicle speed available.
What's going on with the speedo gear on the transmission that it continually requires replacement? They can and do break/wear/get chewed up somehow, but for the most part it's one of those things that never requires attention for 99.9% of others.
Z28KLR is offline
Old 02-14-2017, 08:57 PM
CPTCO
CPTCO's Avatar
If you just want speedo, you can get an app for that.
CPTCO is offline
