the adaptive learning
Old 05-15-2009, 09:55 AM
ski
ski's Avatar
I believe he's saying that he does not eliminate adaptive learning for the engine because it has to operate under numerous different and variable conditions, but he does eliminate adaptive learning for the automatic tranny. He can also adjust the point at which the auto tranny's torque converter locks up for crisper response.
ski is offline
Old 05-15-2009, 08:47 PM
HypromanGT
HypromanGT's Avatar
...and also the fact that he DOES disable adaptive learning for Open Loop (WOT); remember that the factory tune does adaptive learning for both open loop and closed loop.
HypromanGT is offline
Old 05-15-2009, 09:21 PM
ShadyNinja
ShadyNinja's Avatar
well here is some info.
I was at the drag strip
I made 3-4 passes, and decided to pull the cable to see if resetting the ecu would help out, I left it unplugged while we ate lunch (over 1 hour)
hooked it back up,
made about 5 more passes( temp ,wind etc were all about the same)
the last 5 passes were 1-2 tenths slower
Resetting the ecu FTL!
ShadyNinja is offline
Old 05-16-2009, 12:15 AM
stealth_GT
stealth_GT's Avatar
I don't know if this means anything, but I swapped tunes at the track.. stayed there for about 6 hours straight, a few 30 minute breaks, but pretty much back to back runs all day aside from hitting the hot dog/hamburger stand a few times.Burp.
On the way home, the car was shifting weird.. it didn't want to shift and it shifted way later then how it normally did before. It's okay now, but for the ride home it wanted to shift at 5k even when I was just cruising. It stayed in gear longer then it usually did, perhaps WOTing it all day did it...
stealth_GT is offline
Old 05-17-2009, 08:17 PM
ski
ski's Avatar
Good catch!
ski is offline
Old 05-17-2009, 08:38 PM
ski
ski's Avatar
hooked it back up,
Hope it wasn't a "liquid" lunch, which will impact the driver mod.
Joking aside, disconnecting the battery may be of benefit only if the car had been driven conservatively beforehand, which yours was not.
WRT the lower et's, were the temp and winds within 1% of those during the initial 3-4 runs? Was the wind direction the same? What about the humidity level? What about the driver mod, e.g., were the launch and shift rpm's identical, and did you slip the clutch, spin the tires, and shift gears exactly the same? So many variables come into play that can impact times.
Also, what were the times for the initial 3-4 runs?
ski is offline
Old 05-17-2009, 08:44 PM
ski
ski's Avatar
You may want to address that issue with Doug.
ski is offline
Old 05-17-2009, 10:12 PM
ShadyNinja
ShadyNinja's Avatar
weather wind sun all wee the same it was a calm sunny day
not a lot going on
car is a auto with stock 3.31 gears so not a lot of wheel spinning going on
the trans shifted about the same all day
I ran sum 13.3-13.4's before the disconnect
after a bunch of 13.6 and one 13.5
Old 05-17-2009, 10:58 PM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
you have to train the nitrous unit to recognize WOT voltage, its a special calibration procedure.
AmericanMuscle4.6GT is offline
Old 05-18-2009, 02:35 AM
kcmarti
kcmarti's Avatar
Seems to me that this is just the adaptive learning - it learned it was at the track and wanted to keep on going on the way home. You will know for sure if it returns to a more normal feel after a some driving.
kcmarti is offline
Quick Reply: the adaptive learning
