Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-02-2009, 03:14 PM   #1
jgordon
Vehicle: 2001 mustang gt
Question 3.73 gears
when i bought my stang the dealer said it was bone stock.after a couple weeks,the diff cover was leaking,took it back to dealer for repair,and i watched as they took the cover off,to see it has 3.73 gears,i know stock gears is 3.27,my speedometer reads 10mph slow,can you tell me how to make it right?also my rpms are 2000 at 70mph? i know that dont sound right.i ckecked my mph with the odometer in test mode,would the test mode be right?
jgordon is offline   Reply With Quote
Old 10-02-2009, 04:46 PM   #2
Goldenpony
Goldenpony's Avatar
Quote:
I know what you are talking about. Actually it looks like you're writing about a 2001 Mustang. I had a 2000 GT and had 3.73 gears installed and had the same problem. I tried taking it to Ford and they said they couldn't set any gear ration that wasn't offered from the factory. I don't think your odometer test mode will work either since the computer still thinks you have 3.27 gears. If I remember right, they (Ford dealer) changed the computer setting to different size wheels which reduced the speedo error but didn't eliminate it.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
5 Speed
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 93 octane tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 10-03-2009, 09:53 AM   #3
jgordon
Default speedo error
should my speedometer be reading fast instead of slow?would my tach be reading right?
Old 10-03-2009, 11:09 AM   #4
Goldenpony
Goldenpony's Avatar
I believe your speedo will be reading too high. Your tach should be reading OK.
__________________
5 Speed
MGW Shifter
Old 10-03-2009, 06:25 PM   #5
jgordon
my speedometer is reading 10mph slow.so if should be reading fast?
Old 10-04-2009, 03:30 PM   #6
candymanjl
Vehicle: 2009, Mustang GT
if your speedo is calibrated for the stock 3.31 rear end ratio and you have 3.73's then the speedo will read faster than what you're actually going. now if you went from 3.73's to the stock 3.31's then you would be going faster than what the speedo says.
__________________
2009 Mustang GT - Hurst Short Shifter
13.9 @ 100.5mph, 2.1 60' (Density Altitude: 1985 feet)
candymanjl is offline   Reply With Quote
Old 10-04-2009, 06:09 PM   #7
jgordon
my speedometer is reading 10mph slow,so its doing the opposite.
Old 10-04-2009, 06:11 PM   #8
jgordon
thats not making sense why my speedo is reading slow,right?
2001, 2006, 2010, 373, 50, ford, gear, gears, gt, motorsport, mustang, parts, speed, speedometer, top
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
