True trac diff ????
Old 01-27-2011, 10:37 PM
pqtiii
pqtiii's Avatar
Default True trac diff ????
My spider gears are toasted and was thinking about a swapping out a new carrier. I have seen the true trac setup mentioned a few times.
What is the difference between the true trac and the stock unit? I need something that will hold up to 500hp range.
Thanks
pt
pqtiii is offline
Old 01-28-2011, 08:09 PM
SpartaPerformance
SpartaPerformance's Avatar
Standard differential uses clutches to transmit power to the wheels the Truetrac diff. uses helical gear sets to transmit power to the wheel with most traction.
SpartaPerformance is offline
Old 01-29-2011, 03:24 PM
6-Speed
6-Speed's Avatar
The True-Trac and Torsen T-2 are both clutch-less and should offer better performance as a LSD. No friction modifier is needed, and the recommended gear oil may be different than what Ford recommends. I'd check with the LSD manufacturer to see what type of gear oil they recommend in terms of weight and synthetic vs. non-synthetic.
6-Speed is offline
Old 03-17-2012, 07:57 PM
rastarocket
rastarocket's Avatar
Im lookin into gettin one of these myself. the only thing i wonder is how much can i depend on the truetrac always lighting up both tires? i dont want to deal with something that gets confused, id like to know that if im stopped and nail it, both tires are gonna be pushing me! is that the case with the truetrac or should i go with a locker?
rastarocket is offline
Old 03-18-2012, 08:25 PM
Campo 427R
Campo 427R's Avatar
The Detroit Locker differential is a good helical gear LSD for the drag strip duty. It is currently being installed in my Mustang. It thought it would be wise to change over to Moser axles and a low profile girdle cover with torque caps which will give the diff. more strength when under load.
I also went with Royal Purple Max Gear 75W90 because of proprietary synthetic additives that protect the diff. per my race mechanics reccomendation.
This should be a bullet proof set up for our needs.
I get the car back next week and can tell you how well both tires hook up.
Campo 427R is offline
Old 03-18-2012, 11:39 PM
Diabolical!
Diabolical!'s Avatar
Check out the wavetrac. I'm pinching pennies for it.
Diabolical! is offline
winner99
09-30-2015 07:04 PM
67LimeCoupe
09-30-2015 04:46 PM
treesloth
09-28-2015 07:03 AM
09-16-2015 07:53 PM
fastbackford351
09-12-2015 09:42 AM
Quick Reply: True trac diff ????
