Acceleration Issue
Acceleration Issue
08 GT automatic. 90,000 miles. When accelerating on the highway as to pass someone, but not kicking it down, there is a bog down. However if you ease off the pedal, it accelerates normal. TPS?
It's either related to the TSB for the fuel pump (after cruising at a steady speed for a certain period of time, air bubbles form in the fuel pump where going near WOT or WOT forces these bubbles thru the fuel system causing hesitation) or your TCS is causing you to cut fuel/spark. I had the latter issue and make it a habit to turn off TCS unless the roads are wet.
Quite true and I'd be surprised if it WAS the same issue as the TSB calls out but we've seen other TSB's for specific years which were also applicable to the later year models.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
LivingInThePast
09-16-2015 12:20 PM
zanemoseley
09-06-2015 12:58 PM
