Dyno Numbers =S
#21
now I'd bet if someone shot up your car with tracer rounds and caused the gas tank to burn then the N2O tank would be heated and might go over the pressure limits if the safty valve failed due to heat, and if the fire were hot enough before it poped then it might eb hot enough to split the N from the O and have add to the fire
but if you had tracer rounds then the ATF will be after you as they aren't legal for civilian use.
#23
in what I said I ment its a compressed gas, and when a compressed gas exceeds the pressure limits of its container the container may bust.
of course there should be a safty valve but what if the heat has already rendered the valve useless
#24
Actually its even been proven that if you shoot up a gas tank with normal anmo it won't explode (now tracers and incendiary can)
#25
we need to worry someone might start using them on gas tanks
(you can see them because of the flame that make)
#26
If the bottle did get punctured the car would fill up with gas - and other than the irritant that is put in nitrous for car use (so people don't use it in other recreational ways) it would not blow up. Nitrous itself is not even flammable.
(please, not "nos" - that is ricer talk from fast and furious, NOS is a trade name, same as Zex, for a nitrous system. The gas is N2O)
But having gone from nitrous to a supercharger it is a lot easier and more consistent in my experience having the blower. The nitrous was great and a lot of fun, but trying to find a shop in early spring or late fall race season that was still filling bottles was a pain. Plus, every trip to the track meant an extra $35 - $40 to fill the bottle. With the blower, the power is always there ready to be tapped when I need it.
#27
#28
You can use these bad boys
http://www.ammunitiontogo.com/produc...bhr0jl0ahr3j87
#29
I second that, they sell tracers at my local machine shop/gun store (gotta love Texas..one stop shops!)
Hell, a lot of people don't realize you can legally own silencers...$200 tax stamp and some paperwork!
Anyway, OP...is your car tuned for 93? you'd definetly pick up some more numbers if it isn't
#30
