Dyno Numbers =S
Old 01-17-2012, 11:40 PM
SD05GT
SD05GT's Avatar
Default Dyno Numbers =S
So a little background. I had a kenne bell 2.6L supercharger on my car for about 3 years. The car made 462 rwhp and was a dream to drive. I finally spun a bearing in cyclinder 8 due to an oil pump failure. Work was kind of slow so I ended up selling the kenne bell and used the money to have MMR in ventura CA build me a 5.0 stroker. So these numbers are an MMR 5.0 stroker, with comp cams, a full mac exhuast; steeda cai, delete plates, and udps.
How do you thinks the numbers are? Tuner said he could have gotten another 5 - 10 hp if the car had 91, i brought it in with 87. I figure no blower, why get 91...
Car made 331 rwhp and 326 rqtq
SD05GT is offline
Old 01-18-2012, 12:26 AM
808muscle
808muscle's Avatar
Always premium dude....premium=power. Are you happy with the results?
808muscle is offline
Old 01-18-2012, 06:20 PM
breathegood
breathegood's Avatar
Where is your torque curve? That 9:1 compression ratio is just begging for boost. I imagine that if you had that at around 9.8:1 (stock), it would be laying down significantly higher numbers. The important question is, are you happy with the way it drives?
breathegood is offline
Old 01-18-2012, 07:21 PM
rdsx18
rdsx18's Avatar
I'm hoping for 330 with my car with an intake, tune, exhaust, delete plates and NSR Comp Cams, so I'd expect better from that. Problem number 1 is MMR, my buddy had them build his 5.0 stroker for his 99 Cobra, made 361 to the wheels but his was high comp too. I say was because it cracked a valve spring shortly after, so he got it fixed and made 401 this time with a new manifold on it, and promptly broke again. Sent the motor back to MMR and as soon as his car is back together he wants to sell it, last I heard. Anyways, not to be too off-topic, but as you can see I am biased and wouldn't trust MMR. However, 330 does sound good for those mods on a 4.6, but I would think being stroked would help it some too.
rdsx18 is offline
Old 01-18-2012, 11:49 PM
SD05GT
SD05GT's Avatar
Yeah I get you guys on the 91 ontane. I mean it runs alright, but before this, I had a supercharged car lol. Definitely not the same power it used to have, but it runs and it didn't cost much to get back together; just a supercharger =(!
You're right breathegood. I had it built with low compression just for that reason. I want to ad boost again one day. Probably run 16 lbs (which i think is the most you can run on pump gas)since the engine is rated up to 1,000 rwhp. I could have gone 12:1 compression or some odd high numbers like that and it would probably be closer to 400 rwhp right now.
About MMR. God I hope i don't have problems like that. There were local and fairly priced and seemed to have a good rep which is why I went with them. Only complaints are they were supposed to have the engine rebuilt within 3 weeks and it took 2 months. Also the engine was leaking oil from the rear main seal. Not sure if it's MMR's fault or the guy that installed the engine back in. I ended up buying stop leak at autozone. Think it stopped the leak.
SD05GT is offline
Old 01-19-2012, 06:27 AM
rdsx18
rdsx18's Avatar
Ya hopefully it works out for you, and who knows with my buddy, it could have been just a bad batch of springs, but it did take them a long time to get his motor to him. Do you have any head work done and which stage 2 cams do you have, NSR, VSR, or SPR?
rdsx18 is offline
Old 01-19-2012, 03:55 PM
SD05GT
SD05GT's Avatar
I have these cams. http://www.brenspeed.com/127300.html
No heads or headwork done. When I save up money and get another supercharger, I would like to throw some heads on. I never made the investment because it seems like there $2,000.00 + and only net about 30 horsepower. Doesn't sound like that best investment; but I would like to have them anyway. lol
What heads are the best bang for the buck?
SD05GT is offline
Old 01-19-2012, 04:02 PM
rdsx18
rdsx18's Avatar
No idea, I honestly never looked into them because they just don't seem to be worth it. You can make great power FI without them.
rdsx18 is offline
Old 01-19-2012, 06:31 PM
SD05GT
SD05GT's Avatar
Yeah that was kind of my thought process as well. I guess once you get to a point where you have a supercharger and still want power; you go that route. Then again some people try to get as much power as they can while remaining natrually aspirated. I myself miss my supercharger. lulz
SD05GT is offline
Old 01-19-2012, 06:44 PM
rdsx18
rdsx18's Avatar
Ya my buddy tried that with his MMR motor, made good power but broke like I said so it has really turned me off on trying to stay all motor. I'd rather spend the same money and make more power with a supercharger.
rdsx18 is offline
Quick Reply: Dyno Numbers =S
