Stock whipple pulley ?
Old 01-18-2012, 10:56 PM
Lethaldosage423
Lethaldosage423's Avatar
Default Stock whipple pulley ?
What size is pulley that the whipple comes with and that's the boost. I know they make smaller pulleys but I haven't found any info on what the original size and boost is
Thanks in advanced
Lethaldosage423 is offline
Old 01-19-2012, 11:49 AM
duckbubbles
duckbubbles's Avatar
My Ford Racing Whipple came with a 4.0 inch. Depending on outside temperature, it would make around 9 psi. There are many different sizes available through aftermarket vendors and supposedly through Whipple.
Frank
duckbubbles is offline
Old 01-19-2012, 12:26 PM
danzcool
danzcool's Avatar
Depends on when it was purchased new and whether it was an intercooled kit or not.
mine was purchased 03/2010 as the intercooled kit came with 3.125, supposed to do about 12lbs boost.
danzcool is offline
Old 01-19-2012, 09:19 PM
MurrietaStang
MurrietaStang's Avatar
Same here. Mine was ordered in December 2011.
MurrietaStang is offline
Old 01-19-2012, 11:24 PM
Lethaldosage423
That's the answer I was looking for, thank you!!!
Old 01-20-2012, 01:21 AM
Diabolical!
Diabolical!'s Avatar
The stock Whipples came with anything from a 3.125 to a 4.0" pulley. I've seen 3.125, 3.25, 3.375, 3.50, and 3.625 myelf.
Diabolical! is offline
Old 01-20-2012, 01:23 AM
Diabolical!
Originally Posted by duckbubbles
My Ford Racing Whipple came with a 4.0 inch... around 9 psi.
Are you sure? The 4.0 shouldn't make more than 6-7 psi max.
Old 01-20-2012, 08:58 AM
duckbubbles
On a nice 30-40 deg. day I would make 9-9.5 psi. During the heat of the summer (90-100), 5 psi. A big difference depending on OAT.
Frank
Old 01-21-2012, 01:09 PM
Lethaldosage423
i was curious because im looking at the saleen gauge pod and they offer a 10 PSI boost gauge and a 15 psi.. looks like ill be getting the 15 PSI
does anyone know if the saleen boost gauge hooks up to the whipple? im sure it does but i want to be sure before i spend the money!
Old 01-21-2012, 05:38 PM
07vbluestang
07vbluestang's Avatar
mine came with 3.375 and it was 11 lbs. i put kooks 1 3/4" lt and 3" h pipe and lost 1 1/2 lbs. boost.
07vbluestang is offline
Granatelli Sales
03-21-2016 06:16 PM
spdeplayer2
10-24-2015 09:45 AM
FivePointToTheOh
09-29-2015 12:53 PM
ctgreddy
09-20-2015 08:35 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Stock whipple pulley ?
