Motorcraft SP514 Spark Plug
Old 02-13-2012, 08:36 PM
  #21
BAB GT
BAB GT's Avatar
I had my learning curve this weekend. I got the 514's from AM on clearance, and in my arrogance and ignorance I thought if I followed all the rules I would not need the Lisle 65600. 3 broken plugs later, I was begging the local CarQuest to sell it to me for $98.79 with tax. The sight and sound of porcelain powder in my engine made me sick. I used a shop vac with Tygon tubing, an air compressor with a drinking straw taped to the end, and Q-Tips taped to a chop stick, but I am certain I did not get it all. Due to the recurring nightmares and the lingering smell of PB in the garage and the house, I will be putting 7989's in within the next few months.
BAB GT is offline
Old 02-13-2012, 08:45 PM
  #22
DTMR
DTMR's Avatar
so i have the code for the later plugs (thank god) so should i just stick with the motor craft ones when I change or should I get Champions instead
DTMR is offline
Old 02-14-2012, 06:22 AM
  #23
S197GT07
S197GT07's Avatar
Stick with the motorcraft ones if you have the redesigned heads
S197GT07 is offline
Old 03-06-2012, 10:45 PM
  #24
Blkpwr
Blkpwr's Avatar
But the ones you just broke were the stock ones not the sp514s, right?
Why would you change out the 514s?
Blkpwr is offline
Old 03-07-2012, 06:12 AM
  #25
S197GT07
S197GT07's Avatar
I think he broke the stock ones.
Again, the reason the stock plugs are breaking is NOT because they are a 2 piece, it was the copper they used on the electrode that would corrode and bond to the head. All the new plugs now, even 2 pieces, use a nickel plating so that doesn't happen.
Changing out the SP514's is going to be kinda stupid. But if the $12/each champions make you happy go for it. I've heard they are hit or miss with performance.
S197GT07 is offline
Old 03-07-2012, 06:43 PM
  #26
moosestang
moosestang's Avatar
The autolite and ford racing plugs must be made differently, cause I've had mine out half a dozen times or more with no issues.
moosestang is offline
Old 03-07-2012, 07:26 PM
  #27
S197GT07
S197GT07's Avatar
They are made by the same company! And the autolites are 2 piece as well!
Thus making my comments more meaningful, that it doesnt matter if its a 1 or a 2, its the coating on the electrode.
S197GT07 is offline
Old 03-08-2012, 02:16 AM
  #28
chaoscentral
chaoscentral's Avatar
So any new plugs will have the nickel coating? When I'm doing my blower install next month I want to go 1 step colder and was thinking HT0s instead of the brisk plugs.
chaoscentral is offline
Old 03-08-2012, 06:07 AM
  #29
S197GT07
S197GT07's Avatar
Yes, all the newer plugs will have the nickel coating, thus not fusing to the head.
HT0's are your best bet.
S197GT07 is offline
Old 03-08-2012, 11:35 AM
  #30
Blkpwr
Blkpwr's Avatar
Default Autozone sp 514
I bought the sp514s at autozone for 101$ then read this forum and ordered them from American muscle for 69
Blkpwr is offline
Quick Reply: Motorcraft SP514 Spark Plug
