Belt slipping on Whipple (12 psi)
Old 03-31-2012, 12:27 PM
Whippled06
Whippled06's Avatar
Default Belt slipping on Whipple (12 psi)
We recently installed a steeda belt tensioner, and finally took the car to get it tuned and dynod at a local shop however on the way there i noticed the boost gauge was reading 8-9 psi at the highest points. Sure enough, the belt kept slipping on the dyno and couldnt get accurate numbers. Im sure the problem isnt caused by the tensioner, I'm just trying to find a cheaper solution than the belt conversion kits. It read 12 psi just as it should have for a couple months and now the belt continues to slip and squeaks loudly wot. Appreciate any opinions!
Whippled06 is offline
Old 03-31-2012, 04:17 PM
HxCGuitars
HxCGuitars's Avatar
How old is the belt?
HxCGuitars is offline
Old 04-01-2012, 07:30 AM
moosestang
moosestang's Avatar
In order to get the proper tension on my belt. I have to hold the tensioner tight using a breaker bar, then use a piece of wood and rubber mallet to move the whipple sliding tensioner pulley down far enough. I loosely tighten that 3/4 inch bolt on the whipple tensioner, tight enough so it will not move on it's own, but not so tight that I can't force it down using a 1x2 and hammer.
It's easier to do with two people, but I can do it by myself using my inner thigh to keep pressure on the breaker bar and stock tensioner. If you are having a hard time picturing this, it's because I'm standing on the radiator support.
Look at the whipple install instructions. There's a picture of the tensioner and where it needs to sit to prevent belt slippage.
http://home.comcast.net/~cookpaging/...ls/whipple.pdf
moosestang is offline
Old 04-01-2012, 08:19 PM
908ssp
908ssp's Avatar
Here is what you need a Frankentensioner. The spacers are available from DOB. Much cheaper than those custom units that don't work.
908ssp is offline
Old 04-03-2012, 11:14 PM
Diabolical!
Diabolical!'s Avatar
When you say "steeda belt tensioner", are you referring to their tensioner or their dedicated belt drive?
Diabolical! is offline
Old 04-04-2012, 07:21 AM
Whippled06
Whippled06's Avatar
Tensioner
Old 04-04-2012, 01:03 PM
Diabolical!
My first advice would be the same as moose. Tighten up that sliding tensioner as much as humanly possible. If that doesn't cure it, I'd recommend the Thump_rrr tensioner. I don't know of anyone that hasn't been successful with the thump_rrr.
Old 04-04-2012, 02:17 PM
onederful100
onederful100's Avatar
+1
i have a thumprrr and it works great.
i also have the 8 rib kit and that works great too.
for most the tensioner is enough until you get to higher boost.
onederful100 is offline
Old 07-05-2012, 09:58 PM
blown88coupe
blown88coupe's Avatar
I hear everyone talking about the thumb tensioner, so i checked it out. Called them and they told me flat out that is a STOCK tensoner spring in there billet housing.
blown88coupe is offline
Old 07-05-2012, 11:09 PM
danzcool
danzcool's Avatar
Whatever, but the thump racing one works. Can't argue with the track record. 11psi everytime.
danzcool is offline
Quick Reply: Belt slipping on Whipple (12 psi)
