Broken Axle!?!
Old 08-28-2012, 11:04 PM
Justinsmt88
Justinsmt88's Avatar
Exclamation Broken Axle!?!
So I took a corner a little fast lost control, spun out and smacked into a curb. The force of the impact snapped the axle and rotor completely off the car and some how my caliper still works. The problem is I have no clue how to get the broken shaft out of the axle housing. Any ideas?
Justinsmt88 is offline
Old 08-28-2012, 11:16 PM
05gtdriver
05gtdriver's Avatar
Need to drop the rear cover, these Mustangs have C-Clips to secure the axle shaft.
05gtdriver is offline
Old 08-29-2012, 04:21 AM
moosestang
moosestang's Avatar
Yeah, you've got to remove the diff cover and pull the c-clip. then you can push it out from the inside.
Don't hit curbs!
moosestang is offline
Old 08-29-2012, 05:26 PM
Nuke
Nuke's Avatar
The curb is going to sue...
Nuke is offline
Old 08-29-2012, 06:58 PM
Chevy Convert
Chevy Convert's Avatar
I'd be sure the housing isn't bent....
Chevy Convert is offline
Old 08-30-2012, 09:15 AM
uberstang1
Chupacabra
uberstang1's Avatar
That must of been a hard hit, but like others mentioned pulling that axle out would be the same as pulling a good one out. Remove the diff cover draining the fluid, the 8.8 diffs use a lock shaft, its held in place by a small 8mm headed bolt, remove this bolt and spin the diff untill it falls down, the S clip will keep the spider gears in place. One the shaft drops down simply push in on the axle so the inside end and c-clip is expose. Remove the c-clip then the axle will slide right out. I would replace atleast the axle seal on the side while its appart, even the outer housing bearing if you have a puller.
uberstang1 is offline
Old 08-30-2012, 09:30 AM
Justinsmt88
The housing looks good but my panhard bar, sway bar, axle seal and bearing are done for. I hit it at about 30-35 mph, I just cant believe it took the whole axle out. So once I pull the c-clip I can just push the axle out from the inside?
Old 08-30-2012, 09:44 AM
uberstang1
Chupacabra
uberstang1's Avatar
Yea it will slide out. Make sure the lock shaft as c clip dodnt get damaged from the jar either.
Old 08-30-2012, 09:56 AM
JDWalton
JDWalton's Avatar
IMO, if you did that much damage to the rear end... maybe look at a whole replacement axle from newtakeoff.com or similar site. In the long run might save you a bunch of time for about the same amount of cash as parting the whole thing back together.
JDWalton is offline
Old 08-30-2012, 06:12 PM
pascal
S197 Section Modder-ator
pascal's Avatar
JD's right.
Dump the whole thing.
Maybe get a NewTakeOff with different gears...?
pascal is offline
Quick Reply: Broken Axle!?!
