Spark knock, no power.
I'd contact a good local tuner and just have the thing dynoed. Let them sort it out and give your car the power it deserve with those mods.
The thing is , I drove the car with the sct tune and cams for 4 months with no backfiring or spark knock without a tune, so before I put it on a dyno and blow it up, I would like to fix the above issue.
New plugs, I did a smoke test, no leaks from anywhere. Fuel filter is new. Fuel pressure was around 40 @ idle.
I got a few o2 codes yesterday after driving in a heavy rain, I do have home made extenders on them for the headers. Can I unplug those and see how it does in open loop putting around to rule out o2?
popping through the intake is a lean condition
get yourself a data logger and check to see what the hegos are doing and how much fuel correction is getting applied
your best bet for DIY tuning support is http://www.efidynotuning.com/forum
