Battery problems
Old 01-26-2015, 10:50 PM
Simon1
Simon1's Avatar
To fix the bad ground all you do is clean the surface, make sure the wire is connected properly and put it back together. It should not be expensive.
Simon1 is offline
Old 01-29-2015, 07:17 PM
algregory
algregory's Avatar
Not quite a match for this thread, just wanted to throw this in. About a week ago I got the feeling the "start" didn't feel/sound quite as it should. Checked the battery fluids, they looked good, put my Sear's Automatic Charger on it 10 Amps figured it would turn itself off within hour or two. FIVE hours and change later it was still running. Turned it off, looked into cells. I've been tinkering with cars for maybe 40 years. I do not recall ever seeing brown water in side a battery before, all cells, and the level was up a bit to boot!
algregory is offline
Old 01-30-2015, 12:54 PM
d220
d220's Avatar
i dont have a hood light and it is still in the shop the story continue's But they gave me a new 15 to drive until they figure it out. Alot of head scratching going on will let you know what if anything they find
d220 is offline
Old 02-08-2015, 06:43 AM
d220
d220's Avatar
Well it turned out to be a short in the fuse box they put in new box and the problem went away, and they didnt charge me for the box and labor
d220 is offline
Old 04-06-2016, 04:50 PM
fmog44
fmog44's Avatar
The new batteries are good for 5 years!? How far up do I fill the ports? They look low but I'm not sure on this car.
fmog44 is offline
Old 04-07-2016, 05:45 PM
BrianK
BrianK's Avatar
I don't have a hood light - now I want one! A short in the fuse box had to be tough to track down. Electrical problems are tough.
BrianK is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Battery problems
