Grooved idler pulley replacement
Old 01-29-2015, 03:25 PM
6bangr
6bangr's Avatar
Default Grooved idler pulley replacement
I’ve got the cold start squeaks coming from the grooved lower idler pulley. It’s definitely wobbling a bit so I was going to replace it. Marked with the green arrow below.
I’ve found two different part #’s for it but I have no idea which one it is:
1L2Z-6C348-AA
OR
6L3Z-6C348-A
Does anyone know what the difference is between these two?
6bangr is offline
Old 01-29-2015, 08:48 PM
Simon1
Simon1's Avatar
Take it off the car and drive it to the parts shop. It's the easiest way. They can look at the bearing and make sure the get the correct back spacing, width and diameter. Might as weel see if there is matching pulley and replace it too. I've broken pullies before and it stranded me.
Simon1 is offline
Old 02-06-2015, 11:18 PM
tx_zstang
tx_zstang's Avatar
the 6L is a 2007; that will fit fine.
When you change it, do NOT overtighten the bolt. torque spec is 18 ft-lbs.
tx_zstang is offline
Old 02-09-2015, 01:05 PM
6bangr
6bangr's Avatar
Thanks for the replies. The dealership confirmed the 6L3Z-6C348-A is the one I am after. I'm not sure what the story is with the other part #.
I decided to replace the smooth idlers including the tensioner pulley and the bolts while I am at it. That's probably totally unnecessary, but I tend to be overly thorough with my car.
Does anyone know if I should be using Loctite on the pulley bolts?
6bangr is offline
Jb145700
08-21-2022 06:37 AM
OSUTX440
Ohio Regional Chapter
03-15-2021 09:27 AM
5.0muscle
01-11-2016 01:17 PM
Golfsito
10-06-2015 11:02 AM
ctgreddy
09-20-2015 08:35 PM
Quick Reply: Grooved idler pulley replacement
