best aftermarket turbo.
#21
The EDIS cars already have a plug in place of the dizzy and the aux. shaft has the gear on it for the timing belt. I believe you will not use the exhaust coil pack at all but double check on that first.
#22
Are you going to run the turbo in the N/A block or the turbo block?
If your going to use the /A block then I would get it all speced out by the shop before I even touch it with power.
The small journal blocks have a thin cylinder wall casting, making them have less power holding ability and more **** to cracking.
#23
No i am definitely using the turbo block.. thats where my confusion is about the harness set ups. if i use all of the harness's that are there how does the distributor get its wiring. if i use the EDIS with megasquirt how do i plug the holes in the turbo block for dizzy and accessory shaft?
Dan04COBRA
09-30-2015 11:46 AM
09-24-2015 09:18 PM
