Brake Booster?
08-27-2008, 10:32 PM
Brake Booster?
my brakes go all the way to the floor before they start to stop the car unless i pump them a bunch then it gets tighter but they still suck, any ideas? i think its the brake booster but im not sure
08-27-2008, 10:38 PM
Air in your lines, bad brake lines.
Try bleeding your system, if that dosen't help at all then replace the master cylinder
08-28-2008, 11:56 AM
idk how to bleed the brakes and dont you need two ppl for that?
08-28-2008, 08:10 PM
Yes or you can get a DIY kit that allows you to press on the brakes and when you release a check ball falls down stopping air from being sucked in
08-29-2008, 02:22 AM
how hard is it? and the master cylinder is only like 30 bucks should i just replace it anyways? im sure its the original
08-29-2008, 05:13 PM
i thought a bad brake booster would make your brakes Hard? i would think its the master cylinder if bleeding doesnt fix it
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
1988 ,
1989 ,
bad ,
booster ,
brake ,
determine ,
ford ,
mistang ,
mustang ,
rake ,
symptoms
