4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
question about 93 4cyl
Old 07-27-2009, 01:57 PM
Topless06
Topless06's Avatar
Default question about 93 4cyl
I was browsing craigslist and i came across a 93 mustang 4cyl 5-speed for $500. Has new brakes, rad., battery (the normal stuff). But they say it has a rotted cross member and a clutch cable. How hard is this to fix or did this cause some other damage that i wont see. And what else should i look for Thanks!
Topless06 is offline
Old 07-27-2009, 08:24 PM
mg man 75
mg man 75's Avatar
Clutch cable would be no big deal. Now rust out now that maybe if in body. If only in the crossmemeber for the trans. That just bolts in and out. Now front crossmember that is a little more work but if it is rotted out rest of car probably is also. Check that part out real good. Info here on replacing cable.
http://s177.photobucket.com/albums/w...t=100_5991.flv
mg man 75 is offline
Old 07-28-2009, 05:34 AM
Topless06
Topless06's Avatar
Thanks... I called about it and they sold it allready. Well maybe next time ill get one
Old 07-30-2009, 02:32 AM
mustang2.3
mustang2.3's Avatar
i found a 90 around your area for 700 but its an auto.
http://akroncanton.craigslist.org/cto/1289220182.html
mustang2.3 is offline
Old 07-30-2009, 05:00 AM
Topless06
Topless06's Avatar
Thanks. I'll have to give them a call.
Old 07-30-2009, 10:18 PM
mustang2.3
mustang2.3's Avatar
here is a good site to search just put in the keywords and your zip and it will search a certain area from your house but it will only search craigslist
searchtempest.com
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: question about 93 4cyl
