4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
1991 Mustang LX 4 Cylinder Overheating
Old 07-06-2011, 03:04 PM
cpnmark1
cpnmark1's Avatar
Default 1991 Mustang LX 4 Cylinder Overheating
I just purchased a 1991 Ford Mustang LX convertible with a 4 cylinder engine and automatic transmission.
It has 60k original miles on it. I live in the Dallas, Texas (that could be important due to the problem I am experiencing).
I have about a 25 mile one-way commute. The car was over-heating so I replaced the thermostat. That has seemed to only mildly help. The car's temperature now hits the top of the "normal" zone but hasn't overheated (hit the red bar) yet.
Do these year models with the 4 cylinder engines have a history of running "hot"?
Is it just because I live in Texas and it is 100 degrees outside?
Also, my a/c blows VERY COLD until I get about a mile from home (also when the temp gauge is pretty hot). I am not sure if this is related.
Any thoughts from other 91 4cyl LX owners?
Thanks,
Mark
cpnmark1 is offline
Old 07-06-2011, 10:23 PM
mikerp76
mikerp76's Avatar
is your rad fan turning on? if not it could be a realy or the fan switch or the fan itself has failed.
mikerp76 is offline
Old 07-07-2011, 07:23 AM
cpnmark1
cpnmark1's Avatar
Ya, it is working
cpnmark1 is offline
Old 07-07-2011, 12:31 PM
theboss302
theboss302's Avatar
This is how Haynes manual says to trouble shoot overheating.
1. Insufficient coolant in the system
2. Water pump drive belt defective or not adjusted properly
3. Radiator core blocked or radiator grille dirty and restricted
4. Faulty thermostat
5. Fan blades broken or cracked
6. Radiator cap not maintaining proper pressure
7. Incorrect ignition timing
Good Luck
theboss302 is offline
Old 07-11-2011, 08:23 AM
cpnmark1
cpnmark1's Avatar
I changed the thermostat (cost about $10) and still runs hot. I also removed it and car is still overheating. I also saw this morning after my commute, water leaking from a hole on the passenger side of the firewall. Wasn't sure if that was just the a/c drain.
I don't have a thermometer (outside of the one on the vehicle). I'm wondering if it is the radiator.
I'm not sure what else to check for outside of taking it to the dealership for them to diagnose.
cpnmark1 is offline
Old 07-11-2011, 11:49 AM
mikerp76
mikerp76's Avatar
you may need to bypass your heater core. is is a steady drip or is it pouring out while the engine is running. also is it dripping with the a/c off as well. if you have to bypass the heater core you will need 2 90* fittings and some hose if your fan switch is mounted on the hose near the heater core.
mikerp76 is offline
Old 07-13-2011, 12:35 PM
cpnmark1
cpnmark1's Avatar
Mike-
It is a steady drip. It does not seem to be dripping as bad with the a/c off.
Will bypassing the heater core do any damage?
How would I bypass the heater core? I've never done anything like that. Do you know of a youtube video?
Thanks,
Mark
cpnmark1 is offline
Old 07-13-2011, 05:24 PM
mikerp76
mikerp76's Avatar
by passing the heater core won't hurt anything and is easier than replacing it. you will need 2 90* hose connectors and a foot of heater hose. disconnect the hoses from the heater core and insert the 2 90 into them and insrt a small section of heater hose in between them and you are done. just be sure to leave the fan switch on the hose as with out it your fan won't work.
mikerp76 is offline
Old 07-14-2011, 01:09 PM
bl817
bl817's Avatar
check and make sure your radiator is not plugged (bugs/leaves/etc) i replaced mine with a new one (86 bucks) from the local parts store and my car runs noticeably cooler.
bl817 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: 1991 Mustang LX 4 Cylinder Overheating
