4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Spark Plug Replacement
Old 11-12-2011, 04:50 PM
TN yeller stang
TN yeller stang's Avatar
Default Spark Plug Replacement
The stock plugs are Motorcraft AWSF 32C, copper. Should I replace with the same, or upgrade to Motorcraft SP 493, platinum? I purchased a 91 LX I4 and I'm about to change the plugs. I'd like to stick to Motorcraft . . .
Any input would be appreciated. Thanks in advance!
TN yeller stang is offline
Old 11-14-2011, 12:48 AM
7_Zero
7_Zero's Avatar
Most of the info I have read has pertained to the 2.3T and the consensus is that the platinum plugs do not work well with forced induction engines. As for the n/a 2.3 it might not matter. I do not think you will see any major gains by going with the platinum plugs so I would just stick with the copper. IDK maybe someone else might have some better insight on the matter.
Good decision on sticking with Motorcraft though, I've heard these engines are quite particular when it comes to plugs, wires etc. and Motorcraft tend to work the best.
7_Zero is offline
Old 11-14-2011, 02:23 PM
TN yeller stang
7 Zero,
Many thanks for your copper vs. platinum advice! Also, do you recommend Motorcraft spark plug wires then?
Old 11-16-2011, 12:22 AM
7_Zero
7_Zero's Avatar
Well.....that would be the logical answer to my suggestion. However, I am not even running Motorcraft plugs or wires right now. I am running Autolites and some store brand wires. I personally have not had any problems with these, but others say they can be temperamental. My next tune up I was going to change back to Motorcraft though.
7_Zero is offline
Nick Oliver
10-17-2018 04:22 AM
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Spark Plug Replacement
