New Edge 5 lug swap
New Edge 5 lug swap
Finally swapped to 5 lug with 4 wheel disc. The fronts got New Edge spindles, 2 piston PBR calipers and 11" rotors and the rear got a complete axle assymble from a new edge.
D/S front bolted right up with no problems. P/S front I had to make a small brake line to connect the flex line to the existing hard line but other than that it was a straight forward install. I did have to use some washers on the ball joints and where the spindle bolts to the strut because the new edge spindle is thinner in these areas.
The rear end is a direct swap and I used new edge flex lines and made a hardline to connect them together.
I am gonna be putting on a set of stock 2000 v6 rims once I get the tires swapped over.
New front
New rear
rims I will be running
New front
New rear
I knew that was part of the suspension,ive just heard if you drop a v8 in a 4cyl body you will flip the car.But im not going v8 i will eventually go turbo 4 but i just want the right suspension to handle the power i want.
Matt's 95 Stang
10-05-2015 07:16 AM
