4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Help! Mysterious hose...
Old 11-23-2014, 06:50 PM
JDupea
JDupea's Avatar
Default Help! Mysterious hose...
I just replaced the main transmission seals in my 1991 Fox Body, and finished re-attaching the transmission (A4LD, so far as we know.) I have a mystery hose dangling down from the engine with—get this—a hollowed-out wooden dowel stuck in the end. Can anyone tell me where this thing is supposed to plug into?
JDupea is offline
Old 11-23-2014, 07:15 PM
ticopowell
ticopowell's Avatar
just a guess, is it a vacuum hose?
ticopowell is offline
Old 11-28-2014, 04:19 AM
JDupea
JDupea's Avatar
Probably, but I have no clue where it's supposed to go.
JDupea is offline
Old 11-28-2014, 12:29 PM
ticopowell
ticopowell's Avatar
just re-read your first post, the wooden dowel is hollow? as in air gets in? might have had a screw at one point in there to plug it, Also could be some mod that a previous owner did but didn't clean up very well.
Sorry you haven't gotten much help on this :/
Old 11-30-2014, 05:53 PM
JDupea
JDupea's Avatar
We think air gets in. Unsure of whether a screw once plugged it, but it's about 18-24 inches long, and it would be weird to have it dangle so far and be capped at the far end.
Anyone know if any flexible rubber vacuum hoses go to the A4LD transmission?
JDupea is offline
Old 12-04-2014, 10:20 AM
bl817
bl817's Avatar
I want to say that hose goes to the PCV valve but the pic is to small to see. been a while since I had my 93, so going off memory
bl817 is offline
Old 12-11-2014, 02:02 AM
JDupea
JDupea's Avatar
Many thanks! Will check tomorrow.
JDupea is offline
squishbang
12-04-2015 02:29 PM
trashxtrash
09-20-2015 10:49 PM
InsidiousGT
08-28-2006 06:05 PM
Grimace5.0
04-23-2006 09:43 AM
Quick Reply: Help! Mysterious hose...
