Shifter install
Shifter install
Ok i just bought the steeda triax for my car, and was wondering how hard it is to put in? do i have to pull out the center consle to install it?? i finally get to get rid of the sloppy stock shifter, i cant wait to see how it feels!! any pictures of how to install would be great if not ill take some of my install to help people out!! THANKS FOR ANY HELP!!
RE: Shifter install
Dude just get to ur plate on your shifter w/out take everything off....I believe the only problem with ur car is seeing the front two bolts.....Just pull off the bolts, pop the new one in after u set it...seal it up, and bolt it bak in ...shouldnt take more then 30 min....
RE: Shifter install
yeah just pull out the center consule and unbolt the stock one and bolt in teh new steeda one. its a very easy job. Just make sure to put some silcone or gasket maker on so it doesnt leak the tranny fluid
RE: Shifter install
took me 10min with the console in. but it would of went faster without it. console will come out in about 3 min, its easy, you need a 8mm socket, a filpus screw driver, and maybe a trx 20 screw driver.
