free power
Old 05-14-2003, 02:46 PM
ianmgt50
ianmgt50's Avatar
Default free power
I have a 94 mustang gt and I and trying to get as much power out of it without spending any money (college next year). so if you have any cheap tech tips please let me know. Thank you
ianmgt50 is offline
Old 05-14-2003, 03:07 PM
Jameasun
Jameasun's Avatar
Default free power
Remove the Air sliencer.
"The air silencer is a box looking obstruction in front of the air cleaner, it's supposed to quiet down the air rushing into the motor, its blocking the air flow though, therefore removing it nets some power. I am pretty sure on the 4.6 stangs its located in the fender, you may be able to get to it from the engine compartment. Since its a 4.6 Liter, its kind of hard to say how much power you will get, with a 5.0 without a doubt you will get some free power, but some people say removing the silencer on a 4.6 Stang helped with the power, other people (and dyno tests) have shown a slight drop in power when its removed, the only way to find out is to take it out, and see if it feels any better, some things are more throttle response, and overall more power."
Jameasun is offline
Old 05-14-2003, 03:11 PM
Jameasun
Jameasun's Avatar
Default free power
Make sure: to clean your MAF sensor, a tune up, correct tire pressure, new filters (air and fuel).
Jameasun is offline
Old 05-14-2003, 04:20 PM
ianmgt50
ianmgt50's Avatar
Default free power
thanks for the advice but i have a open cone KNN filter so i don't think that the silencer will effect my intake at all. but i will check to see if it is located anywere in front of the filter. Oh yeah by the way it is a 5.0 . Any other advice will be greatly appriciated. thanks
ianmgt50 is offline
Old 05-14-2003, 05:27 PM
converted
converted's Avatar
Default free power
Advance your timing as much as you can and build a ram air setup. After that, you are into the $$$.
converted is offline
Old 05-14-2003, 05:41 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
Default free power
Not really.
Go buy a grinding kit and bore out your stock throttle body. Keep the plate in there so you don't bore where it seals (so you won't have a real high idle). Clean it nice and good, slap it on there. Not free...but damned cheap.
Gained my freinds' '92 POS SL2 AUTO a 1/10 in the 1/4 mile.
jeep45238 is offline
Old 05-14-2003, 06:55 PM
91GT5.0
91GT5.0's Avatar
Default free power
change cone filter to a inside fenderwell set up. hot air coming from engine bay, not to mention the fan wash will mess with the MAF readings
91GT5.0 is offline
Old 05-14-2003, 09:44 PM
lloydchristmas
lloydchristmas's Avatar
Default free power
Shoplift a supercharger
lloydchristmas is offline
Old 05-14-2003, 10:02 PM
Sean
Sean's Avatar
Default free power
Do what 91GT 5.0 said.
Sean is offline
Old 05-16-2003, 06:13 PM
JuiceMan
JuiceMan's Avatar
Default free power
Build your self a CAI its not free but it costs 50$ at most.
JuiceMan is offline
Quick Reply: free power
