93 GT AOD Problem
Old 05-17-2003, 10:53 PM
Justin
Justin's Avatar
Default 93 GT AOD Problem
Hi...I have a 93 GT Conv w/ auto o/d trans......while starting out from a stop the tranny will shift through all the gears correctly but when it goes into o/d it will act as if I took my foot off the accelerator completely or hit the brakes.It will eventually get back up to speed.Also 50% of the time it will not kick down into "passing gear" when I floor it while driving.This is something that happened all of a sudden.It was operating normally and then all of a sudden it started doing it one day.Fluid levels are fine.
Thanks in advance for any feedback
Justin is offline
Old 06-12-2003, 05:22 AM
89 GT
89 GT's Avatar
Hi Justin,</P>
Check your TV cable,sounds like it needs adjusting. The cable will stretch over time and cause alot of strange tranny problems. It canbe adjusted at the throttle body, make sure there is no slack in the cable and that it moves freely with the throttle.</P>
Cheers, Shane </P>
89 GT is offline
69Volunteer
09-30-2015 10:39 AM
marc954
09-25-2015 06:48 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: 93 GT AOD Problem
