Posi Trac Question
Old 04-26-2006, 11:45 PM
black89gt
black89gt's Avatar
Default Posi Trac Question
OK i can get a posi trac for free from a guy i know. posi tracs eliminate the use of hte traction lok clutches right? if so it will be a pretty easy intsall am i correct?
black89gt is offline
Old 04-27-2006, 02:16 AM
waxyourboard
waxyourboard's Avatar
Default RE: Posi Trac Question
Posi trac is chevy's name for a Trac Lok
Pontiac: Safe-T-Track
Ford: Equa-Lock and Trac-Lok
American Motors Corporation: Twin-Grip
Mopar: Sure Grip
Ferrari: E-Diff
They all work on the same principle... clutches, planetary gears, or viscous fluids. All need maintenance, and only one will fit your rear end... the Trac-Lok.
There are plenty of aftermarket units that will fit your unit if you're interested, i suggest the Powertrax unit from my general research.
A Chevy unit won't fit your car.
waxyourboard is offline
Old 04-27-2006, 02:23 PM
5.0coupe
5.0coupe's Avatar
so when ordering gears for the stang u want the gear # and trac-loc?
5.0coupe is offline
Old 04-27-2006, 11:58 PM
black89gt
black89gt's Avatar
no no no i meant he aftermarket like traction lock stuff.. like the ones that do not use clutches.
Old 04-28-2006, 12:00 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
umm...like an eaton rear end? the deal with no spider gears?
FiveLiterRiceEater is offline
Old 04-28-2006, 12:43 AM
frop
frop's Avatar
The only limited-slip diff that doesn't use clutchtes is a Torsen-type geared diff. Auburns use cone clutches, and lockers are no-slip diffs.
frop is offline
Old 04-28-2006, 07:01 PM
black89gt
black89gt's Avatar
ohh ok.. so the carrier is just like the big chunk that ford calls the traction lok? i just need a whole new one.. caus ei dont feel like putting that sideways S shaped spring back in.. its a bitch.. i broke it last time i tried to put it in.. [:@]
Old 04-28-2006, 08:33 PM
ikeybmg
ikeybmg's Avatar
so what kind of diff is it exactly?
ikeybmg is offline
Old 04-29-2006, 11:43 AM
black89gt
black89gt's Avatar
uh i dont really know.. he mentions that it could hold like up to 1000hp its one of those high performance carriers
Old 04-29-2006, 11:47 AM
2 kwik
I ♥ Acer
2 kwik's Avatar
must be a chevy part then
2 kwik is offline
Quick Reply: Posi Trac Question
