My rear main seal leaks a bit...
Old 05-10-2006, 07:01 PM
Twisted
Twisted's Avatar
Default My rear main seal leaks a bit...
How quickly will the leak get worse? Overnight?
Twisted is offline
Old 05-10-2006, 07:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: My rear main seal leaks a bit...
It depends. Mine has been dripping for a few years now. Just a little here and there. Not enough to make me do somethin' about it!!
PRO50SC is offline
Old 05-10-2006, 07:55 PM
ZachW04Stang
ZachW04Stang's Avatar
Join the club. Its pretty common for high milage cars to leak from there. I wouldn't worry about it to much. My oil pan gasket has large pieces of it sticking out of the side of the pan. If I take turns to hard I can loose a 1/4 of a quart. My motor still runs and it has 245k miles on it. Just get used to adding a quart or 2 every couple thousand miles.
ZachW04Stang is offline
Old 05-10-2006, 07:57 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
LOL! Zack, you know you can loosen the pan bolts and shove the gasket back in. Done it a few times on other cars.
PRO50SC is offline
Old 05-10-2006, 08:05 PM
ZachW04Stang
I probably should get the felpro multi piece and put it in. I know it probably won't seal perfect but it will be better then what I have.
Old 05-10-2006, 08:08 PM
Arrid Extra Dry
Arrid Extra Dry's Avatar
i have a 85 f350, with a 351w
my rear main started leaking a little,then worse.
i dropped the pan put an oil pump in it, and took the back main cap off, and was down in the copper
or babbitt.(the gold color ya hate to see)
put a new seal in it, it beat the seal back out because of the slack in bearings
sometimes its not just your seal
im still driving it though,i built a motor for it 7 years ago thinking it would start knocking
still waiting on it too blow up, those windsor motors are pretty tuff, same with a 302
Arrid Extra Dry is offline
Old 05-10-2006, 08:39 PM
marx91
marx91's Avatar
i havent seen a 5.0 that didnt leak a little bit from the rear main lol
marx91 is offline
Old 05-10-2006, 08:41 PM
5.0 MPG
5.0 MPG's Avatar
+1
5.0 MPG is offline
Old 05-10-2006, 11:55 PM
Twisted
Twisted's Avatar
Thanks folks. Good to know that I don't have to cough up money within the next week to get fixed. I'll just ride it until I wear the clutch out I guess. Now I'm wondering what effect the leak has on my oil level, and perceived oil consumption. Maybe I'm not burning as much as I thought I was.
Twisted is offline
Old 05-11-2006, 12:39 AM
razarr69
razarr69's Avatar
mine leaks, it started out as a spot prolly the size of a quarter and over about 4 months it's got to the point where it's the size of a small fist. going to replace it sometime if i ever get around to it
razarr69 is offline
Quick Reply: My rear main seal leaks a bit...
