throttle body
Old 05-11-2006, 11:38 PM
95w.i.p
95w.i.p's Avatar
Default throttle body
I am trying to decide what size throttle body and which one to put in. 65 or 70 and bbk, accufab, edelbrock
95w.i.p is offline
Old 05-11-2006, 11:40 PM
Liquid_02
Liquid_02's Avatar
Default RE: throttle body
What have you done to the car and what are you looking to do in the future?
Liquid_02 is offline
Old 05-11-2006, 11:41 PM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
how big is your maf? i'd go with a 70mm accufab. accufab products are the best. BBK is pretty good too. thats what i use. the only thing thats "bad" about BBK is they whistle and it gets annoying sometimes. i like mine though, sounds like a blow off valve on a turbo and i think bbk and edelbrock are the same.
FiveLiterRiceEater is offline
Old 05-11-2006, 11:43 PM
95w.i.p
95w.i.p's Avatar
w/in the year I am going to throw on a 10 psi supercharger. hopefully trying to push about 450rwhp. not really much now cold air, msd, maf, cat-back, diablo chip
95w.i.p is offline
Old 05-11-2006, 11:44 PM
95w.i.p
95w.i.p's Avatar
24 jet
95w.i.p is offline
Old 05-11-2006, 11:49 PM
Liquid_02
Liquid_02's Avatar
I'd wait on the S/C. You gotta put an intake on it and heads to notice much of a gain with the S/C. You've got a good 4 or 5 grand to spend before I'd start worrying about the S/C. And 450rwhp will blow up your stock short block in a hurry, so you'd have anout 4 or so grand to spend there. You're lookin at around 12 grand to get a supercharger on it.
Just do it in steps. Decide on a H/C/I next and then buy them one by one as the money rolls in, then worry about the TB. You're also going to have to do fuel system upgrades as well once you hit about 300hp, there's a good 7-800 right there. With the mods you have right now a TB isn't going to do anything for you, may even slow it down due to the smaller stock intake opening. Then build up the bottom end THEN I would supercharge it.
My .02
Or you could always just buy a crate motor.
FiveLiterRiceEater
what diameter? you're gonna want a larger diameter maf than throttle body. also if you put a s/c on i think you need a blow through maf. so youll need to buy a new one when you get your s/c
Old 05-12-2006, 12:16 AM
95w.i.p
95w.i.p's Avatar
well right now I am having a problem with the idle it keeps surging, stalling. I also have a vacuum leak and the shop hasn't found it yet but they r leaning towards the throttle body, not really sure yet. I did replace the maf and the iac, no cure yet.
95w.i.p is offline
Old 05-12-2006, 12:43 AM
FiveLiterRiceEater
take some carb cleaner and spray it around your intake and listen for the idle to go up. thatll find your vac leak. as for what liquid said, thats mostly true, and i'll second it, even though i've seen ATI put a procharger on a stock fox and it held fine. it even got a 85% rwhp increase and it was good to go
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: throttle body
