A/C question
Old 05-18-2006, 12:24 PM
collincastaneda
collincastaneda's Avatar
Default A/C question
So...when I replaced my heater core, I had to bleed the a/c system. So, I have no A/C now. I just realized that I either need to search long and hard for someone to be able to recharge the system with R12...or get the R134 conversion. Is the R134 conversion worth it? Or should I just tear out all the A/C lines and components?
collincastaneda is offline
Old 05-18-2006, 12:28 PM
laserred9550
laserred9550's Avatar
Default RE: A/C question
I work in a ch*****et garage, we still use R12, and most times the have retroed a system it took out the compressor, I wouldnt think it would be that hard to find R12, we got a bunch of it.
laserred9550 is offline
Old 05-18-2006, 12:29 PM
collincastaneda
Don't live in Washington do you?
Old 05-18-2006, 12:30 PM
laserred9550
lol no pretty far from there actually, the company i get it from is Johnstone supply may be in your area too.
Old 05-18-2006, 12:32 PM
laserred9550
and you know like i said the comp's were on GM products, i dont know alot about ford comp's, you may be just fine to retro it, this is just what ive seen.
Old 05-18-2006, 01:28 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: collincastaneda
What is the difference?
88BlueGT is offline
Old 05-18-2006, 01:30 PM
laserred9550
two different refrigerants not compatible with each other
Old 05-18-2006, 01:33 PM
88BlueGT
88BlueGT's Avatar
Ohhhhhhhhhhh Ok . thanks
88BlueGT is offline
Old 05-19-2006, 04:24 AM
collincastaneda
Where exactly do you do this R12 refrigerant charging? I just might be up for travelling to you and getting this done because there is no one (that I can find) that can recharge R12.
Old 05-19-2006, 10:24 AM
laserred9550
I am the parts dept. manager at a chevrolet dealership. It would cost you 55.00 labor, 5.00 for a/c system dye, and the refrigerant is 24.95 a lb, most cars are 2-2.5lbs The dealership I work at is in Rockville,IN 47872
Quick Reply: A/C question
