aeromotive fuel regulator
Old 05-22-2006, 12:05 AM
thehourg
thehourg's Avatar
Default aeromotive fuel regulator
i have a aeromotive fuel regulator and am having trouble with some leakage out of the port in the back, i had a fuel line for n2o ran into it, i have since put the stock plug back in, (there is no damage to the treads) but it is leaking, what is the best thread sealer to use, to make sure no fuel gets around those threads? and has anyone else had this problem? my aeromotive is for a sn95....thanks!
thehourg is offline
Old 05-22-2006, 12:07 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
Default RE: aeromotive fuel regulator
they make some liquid thread sealant at autoparts stores. i use that kind of stuff at work and its great. you could also use teflon tape.
FiveLiterRiceEater is offline
Old 05-22-2006, 12:10 AM
tinman
tinman's Avatar
I would CAREFULLY use teflon tape, wrap it with the the treads and you'll have no problems...
Been doing them that way for 25+ years......
tinman is offline
Old 05-22-2006, 12:27 AM
thehourg
thehourg's Avatar
well i did that and the gas turned the tape to mush, and still leaked? i did use some red thread sealer that came in my n2o kit, im fixing to go to the garage to see if that worked? but i was wandering if this problem was common since i am working with alluminum threads?
thehourg is offline
Old 05-22-2006, 06:31 PM
tinman
tinman's Avatar
Sounds like a thread on some fitting is galled out.
Bad thing about the aluminum fittings is just that.
See if you can find a steel fitting to do the job.......
tinman is offline
Old 05-22-2006, 07:20 PM
Tims 88GT
Tims 88GT's Avatar
it should not need anything at all on it. i have an aeromotive regulator and it does not leak a drop. U may have messed up the dighphram inside of it. you are supposed to hook it to the shrader valve.
Tims 88GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: aeromotive fuel regulator
