tps question
Old 04-11-2004, 04:15 AM
88stang5.0
88stang5.0's Avatar
Default tps question
what is the volts and how do you set the tps? some guy said it changes the fuel mixture and what not was wondering if this is true cause my car is running rich? thnx
88stang5.0 is offline
Old 04-11-2004, 07:00 AM
MelloYello
MelloYello's Avatar
Default RE: tps question
Well while using your DVOM rotate the throttle shaft and if there are any jumps or irregularities of the volts you have a bad sensor
the volts should be .9 or 10 for the tps
MelloYello is offline
Old 04-11-2004, 12:22 PM
vfast
I ♥ Acer
vfast's Avatar
start with 0.97-.99 this should put you where you need to be
vfast is offline
Old 04-12-2004, 01:03 AM
roundman
roundman's Avatar
using a digital Volt, Ohm meter and check the voltage from the TPS sensor with the key on but motor off. voltage should be .95-.99 volts with the throttle closed. you can loosen the two screws holding it on and move it to adjust the voltage although you might need to elongate the slots in order to get it to .95 volts. wide open it should read around 5.0 volts. as you move the throttle, it should change smoothly as the throttle moves. most all of the sensors on the engine use 0-5 volts as the output signal back to the ECU.
roundman is offline
Old 04-15-2004, 08:35 PM
X_L_R_8
X_L_R_8's Avatar
One Way Of Checking The TPS Voltage Is To Get Safety Pins And Stick Them Through The Green And Black Wires...Or Orange And Black..I Forget Which Two It Is. Anyway, Then You Just Touch The Leads Of Your Multi-meter To Those Instead Of Trying To Get A Reading Some Other Way. The Best Way To Get An Accurate Reading On Your TPS Is To Buy An In-line Display. I'm Not Sure Where To Get On Of These At (Maybe Ebay). It Just Plugs Right In Between The Two Existing Plugs On Your TPS. This Is By Far The Best Way To Be Able To Monitor Your TPS Voltage At Any Time.
X_L_R_8 is offline
Old 04-16-2004, 01:59 AM
VertStangGT86
VertStangGT86's Avatar
Migh have to fiddle around with that on mine and see how it's reading.
VertStangGT86 is offline
Old 06-12-2004, 01:09 PM
hunterzach_02
hunterzach_02's Avatar
i know this is an old thread..... is there any reason why i wouldnt be able to get my tps voltage below 4.97, that is as low as i could get it. elongated holes and everything.
hunterzach_02 is offline
Old 06-12-2004, 01:37 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
that sounds like WOT type voltage, the voltage needs to be set with the throttle closed.
mdvaldosta is offline
Old 06-12-2004, 03:15 PM
bmorrisj
bmorrisj's Avatar
oh oh your EEC pin#46 is dead, too high resistance...you need a new eec....
bmorrisj is offline
Old 06-12-2004, 11:52 PM
luckythirteen13
luckythirteen13's Avatar
when i set mine i got over 5.0 when it was closed. then i found out i was using the wrong wires. you should be reading from the black and green. when to try those, it should work.
no one answered the question about if this would change his car from running rich. i was just wandering cause mine is running lean.
EDIT: in response to X_L_R_8 's post about the gauge in the car reading the tps...couldnt you get a regular volt meter gauge and instead of hooking it up to the battery, splice into the black and green wire on the tps and hook the volt meter to that? you know, using those "piggy back" clamp things that when you squeez on them they connect to the wire. although it may be hard to find on that can read such small numbers. most start at 8 volts and go up
luckythirteen13 is offline
Quick Reply: tps question
