WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
Old 06-13-2006, 12:55 PM
  #21
Joel5.0
Joel5.0's Avatar
Default RE: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
ORIGINAL: grabbem88
it's not that bud.....say you are cruising to a stop sign.you push in the clutch..it hangs at 1100rpm...then it just bumps back and forth from 1100rpm to 500 till you come to a complete stop,then maybe it idles where it supposed to be....mine is set at 850 btw.
Do you have a code 67 showing up at KOEO by any chance?....
Joel5.0 is offline
Old 06-13-2006, 01:30 PM
  #22
92hatchLX
92hatchLX's Avatar
Mine idles at 750 when it's cold and 850 when it warms up.
92hatchLX is offline
Old 06-13-2006, 05:12 PM
  #23
grabbem88
grabbem88's Avatar
i didn't see one...didn't have my sox's off...what's the code.
ORIGINAL: Joel5.0
ORIGINAL: grabbem88
grabbem88 is offline
Old 06-13-2006, 05:33 PM
  #24
Joel5.0
Joel5.0's Avatar
Run a KOEO, make sure tranny is in neutral for the test...if code 67 (Neutral safety circuit failure) shows up, the system will think the tranny is in gear all the time, and use a different logic for idle control while you're stopping in neutral.
Joel5.0 is offline
Old 06-13-2006, 06:07 PM
  #25
grabbem88
grabbem88's Avatar
you know what i did have that code i think...nevermind it was code 94...
Old 06-13-2006, 06:28 PM
  #26
grabbem88
grabbem88's Avatar
http://www.corral.net/index.php?cate...2_articleid=19
man i hate computers
Old 06-13-2006, 07:23 PM
  #27
Joel5.0
Joel5.0's Avatar
FYI.......check http://www.my5oh.com/forum/viewtopic.php?t=70
Joel5.0 is offline
Old 06-13-2006, 07:31 PM
  #28
grabbem88
grabbem88's Avatar
The EEC-IV logic DOES NOT allow the operation of the EGR system when an EGR failure code is present. Therefore, no timing advance is added by the system, since the EGR function is cancelled/bypassed.
explain this?....i read all that awhile back....
i plugged it back in like i said...i will add this info..when i put my a9p computer in it runs fine,just the idle hangs high,but doesn't bounce.
Old 06-13-2006, 09:31 PM
  #29
Joel5.0
Joel5.0's Avatar
ORIGINAL: grabbem88
EGR failure code present in the system = EGR delete by the system
No bouncing idle, but high....even when you do a full stop?.......
Joel5.0 is offline
Old 06-13-2006, 10:06 PM
  #30
stanglx2002
stanglx2002's Avatar
ORIGINAL: grabbem88
Mine does the same thing I run the A9L and the car runs like crap and dies and then I run the A3M (cobra computer) and the runs fine with a bouncy idle.
stanglx2002 is offline
Quick Reply: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
