WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
Old 06-15-2006, 08:57 PM
  #41
grabbem88
grabbem88's Avatar
Default RE: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
i hope so...atleast give me a 12.1!!!! this car does cover more ground than before...i just hope my d/r's hold up
they have been on the car since last summer.
grabbem88 is offline
Old 06-16-2006, 10:34 AM
  #42
grabbem88
grabbem88's Avatar
so what are signs of a bad vss?...what mine is doing?..where does the wires go to in translation of the signal to computer?
Old 06-16-2006, 12:06 PM
  #43
Joel5.0
Joel5.0's Avatar
ORIGINAL: grabbem88
Code 29 showing up at KOEO.....you would have to do a pulse check with a scope to confirm there are no problems in pins 3 and 6 at the ECM connector, but I don't think that is necessary....do a clear codes and check how it "relearns" with the VSS connected.....and make sure you don't have a code 67 showing up as well.
Keep in mind that idle, while VSS input is over 3mph, will be higher and it'll "hang" some....that's normal, as long as idle is OK after you get to a full stop.......FYI... OBD-II manual tranny Stangs ('96+) do have a hanging idle (1200 rpms+)...and again, normal....it's part of the "idle strategy" set by Ford.
Joel5.0 is offline
Old 06-16-2006, 12:31 PM
  #44
grabbem88
grabbem88's Avatar
yeah my 98gt got on my nerve's as well.....i see that the tweecer has a vss set up/program?
btw FYI i do appreciate your help.
Old 06-17-2006, 05:05 PM
  #45
grabbem88
grabbem88's Avatar
does it or not?...i hate making new posts.
4cylinderplus2
10-09-2020 07:45 PM
jerrytubes
10-23-2015 12:11 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
